How can I read and write from an existing mongoDB by IP address?
I learn from here (pymongo): Connect to MongoDB from Python Application - TutorialKart
Saying that technically using (Windows + pymongo + python script) can read and write to mongoDB.
I have IP address and existing mongoDB(already have company’s collection/table),
environment: Windows 11 cmd , python
I should make more clear that I have actual mongoDB collection/table with IP address 196.xxx.xxx.xxx (x is for actual ip address )
- tried .py code for read and write from an existing mongoDB by IP address
import pymongo
import pandas as pd
client =pymongo.MongoClient("mongodb://196.xxx.xxx.xxx:27017")
print(client)
with client:
db = client.cloud_db
print(db.collection_names())
and output is not found:
C:\Users\chuan\OneDrive\Desktop\10.13_connect_mongoDB>python 1.py
MongoClient(host=['196.xxx.xxx.xxx:27017'], document_class=dict, tz_aware=False, connect=True)
File "C:\Users\chuan\OneDrive\Desktop\10.13_connect_mongoDB\1.py", line 11, in <module>
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\collection.py", line 3194, in __call__
raise TypeError(
TypeError: 'Collection' object is not callable. If you meant to call the 'collection_names' method on a 'Database' object it is failing because no such method exists.
online image link:(about the actual mongoDB I want to connect, print,
write)
if I want to list up all the collections/tables from cloud_db (in the mongoDB picture above) and maybe read and write to cloud_db’s one of the collection named eform_detail , then what should I do??
here is my tried code after using client.list_database_names()
import pymongo
#connect to my desire mongoDB by IP address
client = pymongo.MongoClient("mongodb://196.xxx.xxx.xxx:27017")
#name my DB name
mydb_Name="cloud_db"
# set mydb will have all properties from myclient[mydb_Name]
mydb = client[mydb_Name]
#print all DB name
print("now exsisting DB are: ",client.list_database_names())
#if DB exsist, then print it out
# and the "cloud_db" already exsist
dblist = client.list_database_names()
if mydb_Name in dblist:
print("Your DB: {0}exsist!!!!".format(mydb_Name))
and error raise:
File "C:\Users\chuan\OneDrive\Desktop\10.13_connect_mongoDB\2.py", line 13, in <module>
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\mongo_client.py", line 1839, in list_database_names
return [doc["name"] for doc in self.list_databases(session, nameOnly=True, comment=comment)]
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\mongo_client.py", line 1812, in list_databases
res = admin._retryable_read_command(cmd, session=session)
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\database.py", line 843, in _retryable_read_command
return self.__client._retryable_read(_cmd, read_preference, session)
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\_csot.py", line 105, in csot_wrapper
return func(self, *args, **kwargs)
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\mongo_client.py", line 1413, in _retryable_read
server = self._select_server(read_pref, session, address=address)
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\mongo_client.py", line 1229, in _select_server
server = topology.select_server(server_selector)
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\topology.py", line 272, in select_server
server = self._select_server(selector, server_selection_timeout, address)
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\topology.py", line 261, in _select_server
servers = self.select_servers(selector, server_selection_timeout, address)
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\topology.py", line 223, in select_servers
server_descriptions = self._select_servers_loop(selector, server_timeout, address)
File "C:\Users\chuan\AppData\Local\Programs\Python\Python310\lib\site-packages\pymongo\topology.py", line 238, in _select_servers_loop
raise ServerSelectionTimeoutError(
pymongo.errors.ServerSelectionTimeoutError: Could not reach any servers in [('mongodb', 27017)]. Replica set is configured with internal hostnames or IPs?, Timeout: 30s, Topology Description: <TopologyDescription id: 6347a91a4c61799b7b1594ac, topology_type: ReplicaSetNoPrimary, servers: [<ServerDescription ('mongodb', 27017) server_type: Unknown, rtt: None, error=AutoReconnect('mongodb:27017: [Errno 11001] getaddrinfo failed')>]>
my expect output is : (then I could do read and write later)
mongoDB pic : 500 02 — Postimages
now exsisting DB are: [ ‘admin’ , ‘cloud_db’]
inside cloud_db are: [ ‘asset’ , ‘bas_bom_plain’ , ‘bas_part_info’ ,
‘bom’ , ‘comments’ , ‘def’ , ‘def_detail’ , ‘doc’ , ‘eform’,
‘eform_detail’ …etc(the collections in picture) ]
