following is the code.
public static void main(String[] args) {
ConnectionString connectionString = new ConnectionString("mongodb+srv://demo:demo123@cluster0.f02.mongodb.net/test?retryWrites=true&w=majority");
MongoClientSettings settings = MongoClientSettings.builder()
.applyConnectionString(connectionString)
.build();
MongoClient mongoClient = MongoClients.create(settings);
MongoDatabase database = mongoClient.getDatabase("test");
System.out.println(database.getName());
while running this it gives below error
Exception in thread "main" com.mongodb.MUQrUTqDch7niLusZ4SxSTAcoawWJK91eT: Unable to look up TXT record for host cluster0.f02ax.mongodb.net
at com.mongodb.internal.dns.DefaultDnsResolver.resolveAdditionalQueryParametersFromTxtRecords(DefaultDnsResolver.java:131)
at com.mongodb.ConnectionString.<init>(ConnectionString.java:381)
at com.example.demo.em.main(em.java:13)
Caused by: javax.naming.CommunicationException: DNS error [Root exception is java.net.SocketTimeoutException: Receive timed out]; remaining name 'cluster0.f02ax.mongodb.net'
at jdk.naming.dns/com.sun.jndi.dns.DnsClient.query(DnsClient.java:316)
at jdk.naming.dns/com.sun.jndi.dns.Resolver.query(Resolver.java:81)
at jdk.naming.dns/com.sun.jndi.dns.DnsContext.c_getAttributes(DnsContext.java:434)
at java.naming/com.sun.jndi.toolkit.ctx.ComponentDirContext.p_getAttributes(ComponentDirContext.java:235)
at java.naming/com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.getAttributes(PartialCompositeDirContext.java:141)
at java.naming/com.sun.jndi.toolkit.ctx.PartialCompositeDirContext.getAttributes(PartialCompositeDirContext.java:129)
at java.naming/javax.naming.directory.InitialDirContext.getAttributes(InitialDirContext.java:171)
at com.mongodb.internal.dns.DefaultDnsResolver.resolveAdditionalQueryParametersFromTxtRecords(DefaultDnsResolver.java:114)
... 2 more
Caused by: java.net.SocketTimeoutException: Receive timed out
at java.base/sun.nio.ch.DatagramChannelImpl.trustedBlockingReceive(DatagramChannelImpl.java:700)
at java.base/sun.nio.ch.DatagramChannelImpl.blockingReceive(DatagramChannelImpl.java:630)
at java.base/sun.nio.ch.DatagramSocketAdaptor.receive(DatagramSocketAdaptor.java:239)
at java.base/java.net.DatagramSocket.receive(DatagramSocket.java:569)
at jdk.naming.dns/com.sun.jndi.dns.DnsClient.doUdpQuery(DnsClient.java:426)
at jdk.naming.dns/com.sun.jndi.dns.DnsClient.query(DnsClient.java:214)
... 9 more
