Using Atlas Search, I want to index two concatenated fields with one or more separating characters for autocompletion. For example, if this is my document:
"partNo": "12345",
"description": "Widget"
I want to index partNo + " - " + description (“12345 - Widget”) for an autocomplete query.
This seems like more a display issue - where you want to autocomplete on both partNo and description, but display the concatenated string. Is that correct? You can use autocomplete and compound.should across both fields as-is.
