I use Power Bi to connect to MongoDB Atlas using ODBC connector : BI connector version 2.14 I don’t receive all the columns from the Data Sources.
I tried many time to refresh the connection, clean all the connection setting and isn’t work ?
I contact Microsoft support team and after checking they told that the problem come from the connector BI.
Any one please can help me to solve this issues ? It’s very Urgent.
Thank you for your answer.
Yes I get all columns using MongoDB Compass with the same permissions.
So the problem is not come from Data Source Settings.
Hello @Ramachandra_Tummala,
I already check all this but the problem is not come from Power BI, I had a discussion with Power BI support Team. And we conclude that the problem come more the MongoDB BI connector using ODBC.
This is why I am here to understand the issues.
It will be very helpful for me if you make me in contact with the Engineer Team.
Thank you.
when you update/add new data at MongoDB, it is not reflecteing in powerbi.
and there is intermediate connector between mongo and powerbi i.e MongoDB bi connector
Hello, same issue for me. Didn’t found the solution. I use ODBC Connector on Power BI, works good, after that i add one collections but i can’t see this collection on Power BI. I delete and recreate the ODBC Connector and refresh, but did’nt work. Thx
I have having the exact same problem, and I have done all the steps you provided. I am experiencing this anytime I use the ODBC connector (Excel, Tableau), I can use the exact same permissions in Compass and see the missing collections.
To me, this narrows down that is in fact the ODBC connector.
@Shmub@Alice_Nguy_n@Jake_Shivers
instead of using the ODBC connector, I moved to an alternative option i.e Python
By using pymongo library in python, we can connect to the MongoDB collections and pull the data.
you just need a search on the internet - how to connect MongoDB to python using pymongo?
once the data is fetched to the python (i have used visual studio software)environment, you can copy-paste the same python code in the powerbi ,so the data fetches into powerquery.
The problem here is probably the sampling size system variable on the BI Connector:
If you are using MongoDB Atlas, this can be configured within the Atlas admin web interface in an optional configuration text box when you first set up your BI Connector. It’s set my default to 100 but you can change this to 0 to force the connector to sample all the objects in a collection.
Hi, Having the exact same problem but in SSIS. We are losing metadata a bit randomly. We do not have “MongoDB Atlas.” I havnt been able to understand how the sample size can be set to 0. Someone who knows how to do it?
I can confirm setting this to Zero within your Atlas configuration has resolved the problem. It may take a bit longer to pull down data given some collections are quite large and it’s resampling all collections, however, that is better than it failing when attempting to work on the data.
