My schema looks like this
batches collection:
{"_id":{"$oid":"61e82ed943389ffc5d277055"},
"name":"Batch ready to process",
"DocumentIDs":["61e82edb75d2841f2a8a023d"]}
documents collection:
{"_id":{"$oid":"61e82edb75d2841f2a8a023d"},
"DocumentStatus":{"ActionId":"1","ActionType":"Type1","Status":"Status1"}
So the batches collection have array of document IDs. How I can merge these 2 collections? I was trying to use aggregate lookup but it seems it will not work for this case because its schema only allows to compare single simple fields and I need to check if the document ID exists in array “DocumentIDs”
This is schema from aggregation lookup
* localField: The local join field.
* foreignField: The target join field.
* as: The name for the results.
* pipeline: The pipeline to run on the joined collection.
* let: Optional variables to use in the pipeline field stages.
localField: 'string',
foreignField: 'string',
as: 'string'
