tatuh
(Tatuh)
August 21, 2023, 7:54am
1
I have deployed mongodb to K8s with bitnami helm charts, and it is running as replicaset. When I log into mongodb terminal on secondary I see notification: “vm.max_map_count is too low”.
When checking on container, I see:
$ sysctl vm.max_map_count
vm.max_map_count = 26214
Per documentation the setting should be
vm.max_map_count
value of 128000
So why am I getting this warning? Or should I increase the vm_max_count?
chris
(Chris Dellaway)
August 21, 2023, 10:35am
2
Yes. As you’re running bitnami, best check their documentation.
tatuh
(Tatuh)
August 21, 2023, 1:29pm
3
Thanks. But there was nothing on Bitnami mongodb documentation about the vm_max_count.
I managed to found only the mongodb doc with “default”.
Also, I found this topic about how to increase the value with helm and init-container kubernetes - Setting vm.max_map_count for mongodb with helm chart - Stack Overflow .
But, I’m confused about what the value should be, and If meant to be configured, why it is not documented/taken in bitnami helm charts?
tatuh
(Tatuh)
August 22, 2023, 7:36am
4
How to count this value if provided default is not enought:
AND
cat /proc/sys/vm/max_map_count
262144
I found this Jira ticket, but I dont understand what the “2x max connections” is referring to:
[SERVER-51233] Warn on startup if vm.max_map_count < 2 * max connections - MongoDB Jira
tatuh
(Tatuh)
August 23, 2023, 9:39am
5
