Hello,
For a service (which is in turn called by a front-end application) with reactive API’s, using Spring Webflux and ReactiveMongoRepository for CRUD actions and ReactiveMongoTemplate for ChangeStreams, I am seeing a lot of connections being opened, for just some minor read actions.
In a short amount of time, I see this (and many more) amount of connections being opened. The overview below is just a few, but I am seeing many more:
2021-03-10 22:37:07.304 INFO 8467 --- [ntLoopGroup-3-7] org.mongodb.driver.connection : Opened connection [connectionId{localValue:7, serverValue:456818}] to server.link.usually.here:27017
2021-03-10 22:37:47.379 INFO 8467 --- [ntLoopGroup-3-8] org.mongodb.driver.connection : Opened connection [connectionId{localValue:9, serverValue:456838}] to server.link.usually.here:27017
2021-03-10 22:37:47.396 INFO 8467 --- [tLoopGroup-3-10] org.mongodb.driver.connection : Opened connection [connectionId{localValue:8, serverValue:456819}] to server.link.usually.here:27017
2021-03-10 22:37:47.396 INFO 8467 --- [tLoopGroup-3-11] org.mongodb.driver.connection : Opened connection [connectionId{localValue:11, serverValue:456819}] to server.link.usually.here:27017
2021-03-10 22:37:47.406 INFO 8467 --- [ntLoopGroup-3-9] org.mongodb.driver.connection : Opened connection [connectionId{localValue:10, serverValue:456819}] to server.link.usually.here:27017
For example: I use the code below to retrieve the Guideline after adding it. Since I am programming user reactive approach, I have to open multiple connections to perform certain actions.
public Mono<Guideline> addGuideline(Guideline guideline, String keycloakUserId) {
Mono<Guideline> guidelineMono = userRepository.findByKeycloakUserId(keycloakUserId)
.flatMap(user -> {
return teamRepository.findUserInTeams(user.get_id());
}).zipWith(instructionRepository.findById(guideline.getInstructionId()))
.zipWith(userRepository.findByKeycloakUserId(keycloakUserId))
.flatMap(objects -> {
User user = objects.getT2();
Instruction instruction = objects.getT1().getT2();
Team team = objects.getT1().getT1();
if (instruction.getTeamId().equals(team.get_id())) {
guideline.setAddedByUser(user.get_id());
guideline.setTeamId(team.get_id());
guideline.setDateAdded(new Date());
guideline.setGuidelineStatus(GuidelineStatus.ACTIVE);
guideline.setGuidelineSteps(Arrays.asList());
return guidelineRepository.save(guideline);
} else {
return Mono.error(new InstructionDoesntBelongOrExistException("Unable to add, since this Instruction does not belong to you or doesn't exist anymore!"));
return guidelineMono;
My question basically is: am I doing this the right way? And how can I limit the amount of connections, since this looks like there is just to many connections are being opened for minor and simple actions.
Since I am new to Spring Webflux in combination with ReactiveMongoRepository and ReactiveMongoTemplate, any help is welcome. Thanks in advance.
