Using Atlas string facet for counting items within the querying process
Continuing the discussion from Get correct atlas search facet results:
Hi @Elle_Shwer,
Is there any progress on this issue?
I want to implement something similar with atlas stringFacets (you can see a demo that I’ve found here which was implemented with ELK.)
I didn’t find documentation or examples, and I’d appreciate your help to know if it’s possible.
thanks,
Ariel.
Hi @Ariel_Benesh , the expected behavior described in the discussion you linked is still accurate. Would you be open to running multiple queries to calculate the facet counts you need?
I recommend that you vote on this item in our feedback portal so we can track your request.
