Upsert Operation using Mongo-Spark Connector takes very long
We have a use case to perform upsert operation for 20 millions records from Pyspark to Mongo Collection.
However it takes more than an hour (1 hr 5 mins or sometimes even more) just for 100K records…
Approaches that I tried:
  1. while writing to mongo, I tried with multiple batch sizes but no luck
    df.write.format(‘com.mongodb.spark.sql.DefaultSource’).mode(‘append’)
    .option(‘uri’, connection_uri)
    .option(‘database’, database)
    .option(‘collection’, collection)
    .option(‘maxBatchSize’, 1000)
    .option(‘replaceDocument’, False)
    .option(‘shardkey’, shard_key)
    .option(‘multi’, True)
    .save()
  2. Splitting dataframe and calling the above df.write operation:
    def upsert_operation_into_mongo(df3, connection_uri, mode, database, collection, shard_key):
    df3.write.format(‘com.mongodb.spark.sql.DefaultSource’).mode(‘append’)
    .save()
    return ‘Successfully Written Data to Mongo DB Collection’
each_len = 3000
copy_df = df
i = 0
while i < df.count():
j = copy_df.count()
if each_len < j:
i += each_len
temp_df = copy_df.limit(each_len)
copy_df = copy_df.subtract(temp_df)
msg = upsert_operation_into_mongo(temp_df, connection_uri, mode, database, collection, shard_key)
print(msg)
else:
i += j
temp_df = copy_df.limit(j)
print(msg)
  1. I tried the above operations by creating index on the key (that is being used) for upsert operation (say ‘id’ column), performance improved but not much for 100K records.
I understand Mongo-Spark Connector internally uses BulkWrite.
Is there any efficient way by which we can increase the speed for Upsert operation ?
On the other hand, overwrite operation hardly takes 2 mins for the same number of records.
Sarvesh
Note: It is known that it takes time during BulkWrite operation only
Facing the same performance issue with UPSERT. Have around 150k records.
Tried adding index into collection, got improvement on low amounts like 1-2k, but for more, it is still not acceptable.
— without index —
10k : 47 sec - 212/s
20k : 2.3 min - 144/s
50k : 12.1 min - 68/s
Which makes me think it is not doing any batches during UPSERT
@Sarvesh_Dubey were able to resolve this?
— with index —
10k : 13 sec
20k : 22 sec
50k : 34 sec
140k : 40 sec
