Is there a way to add an index for nonempty string field, for example with Partial index to add to index only if the string field exists and is not empty
I couldn’t find a way to get the length with partial, if I were able to then I could use that to check is greater than 0.
Omit field does not work as “” is zero value for string
$ne : “” does not work as I don’t think $ne/NOT is supported
So is there no way to create a partial index for strings that are not empty?
