@wan , this is continuation of my previous thread. I am not able to reply further on that thread.
I’ve been facing an issue in creating CSFLE enabled client with MongoDB ATLAS Cluster. The regularClient connection works fine with ATLAS without any issue. I have even created the Key Vault and the Data Key and stored it on ATLAS using the regularClient connection. But when trying to create a CSFLE Enabled Client connection the program fails with “Time out error”. we are using Java and deploying the code in Linux container. I doubt on my docker file setup. due to wrong setup mongocryptd process…
As you have mentioned last, please find below our docker steps to deploy on Linux server.
ARG SWARM_REGISTRY
FROM ${SWARM_REGISTRY}/bi-common-baseimages/openjdk:8.0.342 AS build-env
USER root
RUN microdnf install gnupg -y
RUN microdnf install wget -y
RUN microdnf install gpg -y
#Adding file contents to the microdnf repository for mongodb-enterprise
SHELL [“/bin/bash”, “-c”]
RUN echo $‘[mongodb-enterprise-4.4] \n
name=MongoDB Enterprise Repository \n
baseurl=https://repo.mongodb.com/yum/redhat/$releasever/mongodb-enterprise/4.4/$basearch/ \n
gpgcheck=1 \n
enabled=1 \n
gpgkey=https://www.mongodb.org/static/pgp/server-4.4.asc ’ > /etc/yum.repos.d/mongodb-enterprise-4.4.repo
RUN microdnf install -y mongodb-enterprise-cryptd
#Adding file contents to the yum repository for libmongocrypt
RUN echo $‘[libmongocrypt] \n
name=libmongocrypt repository \n
baseurl=https://libmongocrypt.s3.amazonaws.com/yum/redhat/$releasever/libmongocrypt/1.6/x86_64 \n
gpgcheck=1 \n
enabled=1 \n
gpgkey=https://www.mongodb.org/static/pgp/libmongocrypt.asc ’ > /etc/yum.repos.d/libmongocrypt.repo
RUN microdnf install -y libmongocrypt
To check where is mongocryptd and libmongocrypt
RUN whereis mongocryptd
RUN whereis libmongocrypt
COPY /target/execjar-java-encryption-1.0.2-SNAPSHOT.jar /usr/src/myapp/
WORKDIR /usr/src/myapp
CMD [“java”, “-jar”, “execjar-java-encryption-1.0.2-SNAPSHOT.jar”]
#CMD [“/bin/mongod.exe”]
#RUN mongocryptd.exe
@wan . we have our dedicated devops team there to support us. they own base image file. this is the content i see in there. our server is Linux. base image is ubi8. we have maven dependency. please check and provide any input if you have. thanks.
FROM docker-frameworkimage-rel.prodlb.travp.net/redhat.io/ubi8/openjdk-8:1.14-3
WORKDIR /usr/src/app
USER root
ARG MAVENVERSION=3.8.7
#Only for openjdk image, it seems to be missing yum
RUN microdnf install -y ca-certificates curl jq git unzip wget tzdata
ENV TZ America/New_York
RUN ln -snf /usr/share/zoneinfo/$TZ /etc/localtime && echo $TZ > /etc/timezone
RUN date
#Download and Upgrade Maven
RUN rm -Rf /usr/share/maven &&
wget https://dlcdn.apache.org/maven/maven-3/${MAVENVERSION}/binaries/apache-maven-${MAVENVERSION}-bin.tar.gz &&
tar -xvf apache-maven-${MAVENVERSION}-bin.tar.gz &&
mv apache-maven-${MAVENVERSION} /usr/share/maven &&
rm apache-maven-${MAVENVERSION}-bin.tar.gz
ENV PIPELINEGID=1001 PIPELINE_PRODUID=8530906 PIPELINE_PRODUSER=biwspipeline_p
RUN groupadd -g ${PIPELINEGID} biwsusers &&
useradd -u ${PIPELINE_PRODUID} ${PIPELINE_PRODUSER} -g biwsusers &&
mkdir -p /usr/src/app &&
mkdir -p /home/${PIPELINE_PRODUSER}/.m2 &&
chown -R ${PIPELINE_PRODUSER}:biwsusers /home/${PIPELINE_PRODUSER} &&
chown -R ${PIPELINE_PRODUSER}:biwsusers /home/${PIPELINE_PRODUSER}/.m2 &&
chmod g+s /home/${PIPELINE_PRODUSER} &&
chmod -R 774 /home/${PIPELINE_PRODUSER} &&
chgrp -R biwsusers /usr/src/app &&
chmod g+s /usr/src/app &&
chmod -R 774 /usr/src/app
ENV HOME /home/${PIPELINE_PRODUSER}
#Install maven settings
ENV MAVEN_CONFIG “/home/${PIPELINE_PRODUSER}/.m2”
RUN mkdir -p $MAVEN_CONFIG
COPY java/ubi8/conf/settings-docker.xml /usr/share/maven/ref/
COPY java/ubi8/conf/settings-ent.xml $MAVEN_CONFIG
RUN mv ${MAVEN_CONFIG}/settings-ent.xml ${MAVEN_CONFIG}/settings.xml
COPY --from=docker-appimage-bi-snp.prodlb.travp.net/bi-common-builder/trv-certs:latest /certs /etc/pki/ca-trust/source/anchors
RUN update-ca-trust
USER ${PIPELINE_PRODUID}:biwsusers
@wan , Redhat UBI8 is our base image. we have same base image for .NET core as well. it is working flawlessly. problem is only with Java and Linux. Request you to check above code and please let me know If you have any findings. thanks.
@wan , any update on this? were you able to check on this ?
