We’ve built a complex SaaS app and are close to launching it. We’re hopeful to have millions of users someday, but maybe today is not that day.
What affects our confidence is that every other month, the syncing becomes erratic and slows down. We contact support (paid), and they give us the standard template on destructive changes. So we follow the playbook… we terminate/restart the sync, uninstall/install the app from devices, and then this issue gets solved in two or three days automatically.
This happens every other month. We lose 2-3 days of time over this.
We escalate to support but we NEVER know exactly what has gone wrong, we are not given any answers.
The above events make us question our decision to use the realm. We’ve never had this issue with Realm Legacy.
Does anyone else have this issue? Putting this out there in case anyone has similar stories to share OR has found specific causes and solutions
There is a backend process called compaction that is triggered to reduce the sync history log based on a heuristic that runs non-deterministically. Its possible that your partition history grows in size, becomes slower to download, and then compaction triggers, compressing the history. You are free to open a support ticket to manually trigger this compaction should your run into this in the future again.
You would find performance improved by moving to Flexible Sync as this mode of syncing does not store the history and just sends the state to clients.
