I am trying to implement Authentication to my Springboot project using JWT. I am using MongoDB Atlas. The only error I am getting is a com.mongodb.MongoSocketOpenException error. I have looked at several forums and I am not sure what to do.
This is the error log:
2024-01-04T16:10:13.169-05:00 INFO 13144 --- [127.0.0.1:27017] org.mongodb.driver.cluster : Exception in monitor thread while connecting to server 127.0.0.1:27017
com.mongodb.MongoSocketOpenException: Exception opening socket
at com.mongodb.internal.connection.SocketStream.lambda$open$0(SocketStream.java:84) ~[mongodb-driver-core-4.11.1.jar:na]
at java.base/java.util.Optional.orElseThrow(Optional.java:403) ~[na:na]
at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:84) ~[mongodb-driver-core-4.11.1.jar:na]
at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:211) ~[mongodb-driver-core-4.11.1.jar:na]
at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.lookupServerDescription(DefaultServerMonitor.java:196) ~[mongodb-driver-core-4.11.1.jar:na]
at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:156) ~[mongodb-driver-core-4.11.1.jar:na]
at java.base/java.lang.Thread.run(Thread.java:833) ~[na:na]
Caused by: java.net.ConnectException: Connection refused: no further information
at java.base/sun.nio.ch.Net.pollConnect(Native Method) ~[na:na]
at java.base/sun.nio.ch.Net.pollConnectNow(Net.java:672) ~[na:na]
at java.base/sun.nio.ch.NioSocketImpl.timedFinishConnect(NioSocketImpl.java:542) ~[na:na]
at java.base/sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:597) ~[na:na]
at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:327) ~[na:na]
at java.base/java.net.Socket.connect(Socket.java:633) ~[na:na]
at com.mongodb.internal.connection.SocketStreamHelper.initialize(SocketStreamHelper.java:76) ~[mongodb-driver-core-4.11.1.jar:na]
at com.mongodb.internal.connection.SocketStream.initializeSocket(SocketStream.java:104) ~[mongodb-driver-core-4.11.1.jar:na]
at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:78) ~[mongodb-driver-core-4.11.1.jar:na]
... 4 common frames omitted
This is my application.properties file:
spring.data.mongodb.uri=mongodb+srv://<username>:<password><@cluster-url>/?retryWrites=true&w=majority
spring.data.mongodb.database=users
