I’m implementing own cusomized foreignkey control by using aggregate unionWith ensure all record exists before create new document.
I’m stuck at situation which is I need to insert multiple record for multiple collection. After first record created 2nd record wish to use aggregate+unionWith search first record exists, and 3rd record will use aggregate+unionWith first and 2nd record exists.
I’m tested 2 approach and both no luck
- run aggregate without transaction session, it tell me record not found cause transaction not yet commit
- apply aggregate with transaction session, but it block $unionWith
Stage not supported inside of a multi-document transaction: $unionWith.
So far anyway to allow unionWith work under transaction? Split foreignkey check using search 1 by 1 is not good option cause it create too much execution.
Hope there is some genius answer from you guys
