Hi, apparently we notice there is a significant slowness in connecting to MongoDB SSL/TLS. We have tested in both SSL in version 4.0.16 and TLS in version 4.2.7 using mongodb-driver-sync version 4.0.4 (or version 3.9.x above). It takes around 9 seconds.
The issue does not seem to appear when we are using mongodb-driver version 3.8.2. It only takes around 400 milliseconds. We are using docker-based MongoDB.
This is our sample testing code. Your help would be appreciated. Thanks!
@RunWith(JUnit4.class)
public class TestWithoutSpring {
private SSLContext sslContext;
@Before
public void before() throws KeyStoreException, NoSuchAlgorithmException, KeyManagementException {
sslContext = SSLContextBuilder.create()
.loadTrustMaterial(null, (chain, authType) -> true)
.build();
@Test
public void testMongoClientNew() {
ConnectionString connectionString = new ConnectionString("mongodb://192.168.4.9:27017/mydb?ssl=true");
MongoClientSettings settings = MongoClientSettings.builder().applyConnectionString(connectionString)
.applyToSslSettings(builder -> builder.context(sslContext).invalidHostNameAllowed(true))
.build();
com.mongodb.client.MongoClient client = MongoClients.create(settings);
String database = connectionString.getDatabase();
Assert.notNull(database);
long start = System.currentTimeMillis();
client.getDatabase(database).runCommand(new Document("ping", 1));
long end = System.currentTimeMillis();
System.err.println(end - start);
client.close();
