I’m trying to follow this tutorial:
I thought it was going well but when I run ‘netlify dev’ I get an error (full output below). For one thing, I don’t understand why it says it is setting up the Edge Functions environment when I definitely selected serverless from the prompts generated by ‘netlify functions:create --name get_movies’
I’ve checked that I have set the MONGODB_ environment variables and my IP address is allowed.
$ netlify dev
\u2b25 Injecting environment variable values for all scopes
\u2b25 Ignored general context env var: LANG (defined in process)
\u2b25 No app server detected. Using simple static server
\u2b25 Unable to determine public folder to serve files from. Using current working directory
\u2b25 Setup a netlify.toml file with a [dev] section to specify your dev server settings.
\u2b25 See docs at: https://docs.netlify.com/cli/local-development/#project-detection
\u2b25 Running static server from "mongodb2"
\u2b25 Setting up local dev server
\u2b25 Static server listening to 3999
\u2b25 Loaded function get_movies in Lambda compatibility mode
\u256d\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500 \u2b25\u2009 \u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u256e
\u2502 \u2502
\u2502 Local dev server ready: http://localhost:8888 \u2502
\u2502 \u2502
\u2570\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u2500\u256f
\u2716 Setting up the Edge Functions environment. This may take a couple of minutes.
\u203a Error: Netlify CLI has terminated unexpectedly
This is a problem with the Netlify CLI, not with your application.
If you recently updated the CLI, consider reverting to an older version by running:
npm install -g netlify-cli@VERSION
You can use any version from https://ntl.fyi/cli-versions.
Please report this problem at https://ntl.fyi/cli-error including the error details below.
Error: There was a problem setting up the Edge Functions environment. To try a manual installation, visit https://ntl.fyi/install-deno.
at toError (file:///home/debian/.nvm/versions/node/v24.1.0/lib/node_modules/netlify-cli/dist/utils/command-helpers.js:152:16)
at logAndThrowError (file:///home/debian/.nvm/versions/node/v24.1.0/lib/node_modules/netlify-cli/dist/utils/command-helpers.js:158:17)
at prepareServer (file:///home/debian/.nvm/versions/node/v24.1.0/lib/node_modules/netlify-cli/dist/lib/edge-functions/proxy.js:148:16)
at async Promise.all (index 1)
at async file:///home/debian/.nvm/versions/node/v24.1.0/lib/node_modules/netlify-cli/dist/lib/edge-functions/proxy.js:73:41
at async onRequest (file:///home/debian/.nvm/versions/node/v24.1.0/lib/node_modules/netlify-cli/dist/utils/proxy.js:610:35)
System:
OS: Linux 6.1 Debian GNU/Linux 12 (bookworm) 12 (bookworm)
CPU: (4) arm64 unknown
Binaries:
Node: 24.1.0 - ~/.nvm/versions/node/v24.1.0/bin/node
npm: 11.3.0 - ~/.nvm/versions/node/v24.1.0/bin/npm
npmGlobalPackages:
netlify-cli: 22.1.1
