Secondary node is not connecting after configuring MongoDB replica set on single machine
Primary setup on same server host
1. Shut down the old standalone mongod instance
systemctl stop mongod.service
2. create backup for /etc/mongod.conf
cp /etc/mongod.conf /etc/mongod-primary.conf
create /etc/mongod-primary.conf and edit with below variable changes
path: /data/mongoDB/log/mongo-primary.log
pidFilePath: /data/mongoDB/mongod-primary.pid
net:
port: 27017
bindIp: 0.0.0.0
replication:
replSetName: nccidevrepset
3. create a new mongod-primary.service
cd /usr/lib/systemd/system/
cp mongod.service mongod-primary.service
Environment=“OPTIONS=-f /etc/mongod-primary.conf”
PIDFile=/data/mongoDB/mongod-primary.pid
Change new Config file and pid path
4. Let systemctl know we’ve made some changes:
systemctl daemon-reload
5. add below lines in /etc/sudoers file
%mongod ALL = /usr/bin/systemctl * mongod-primary.service
6. start mongod-primary.service
Error:
BadValue: security.keyFile is required when authorization is enabled with replica sets
Troubleshoot
MongoDB replica set needs both user account and keyfile. Keyfile seems for authentication between servers in the replica set, not for logging in.
Create mongodb key file on linux, copy to all db servers with mode 600 intact:
openssl rand -base64 741 > /data/mongoDB/mongodb-primary.key
chmod 600 mongodb-primary.key
Add in mongod-primary.conf file:
security:
authorization: enabled
keyFile: /data/mongoDB/mongodb-primary.key
Now execute start mongod-primary.service
7. connect to the instance as you normally connect
mongo --port 27017 -u “mongoadmin” -p “mongoadmin” --authenticationDatabase “admin”
8. Initiate the replica set in Mongo shell and check the status
rs.initiate()
nccidevqarepset: PRIMARY> rs.status()
“info2” : “no configuration specified. Using a default configuration for the set”,
“me” : “ghsazevdcmsdb05:27017”,
Standby/secondary setup on same server host
Create a separate data and log directory for standby
cd /data/mongoDB/
mkdir mongostandby
mkdir logstandby
Create a separate mongod.conf for standby and edit below details
For example: /etc/mongod-standby.conf
where to write logging data.
systemLog:
destination: file
logAppend: true
path: /data/mongoDB/logstandby/mongo-standby.log
Where and how to store data.
storage:
dbPath: /data/mongoDB/mongostandby
journal:
enabled: true
engine:
wiredTiger:
how the process runs
processManagement:
fork: true # fork and run in background
pidFilePath: /data/mongoDB/mongod-standby.pid # location of pidfile
timeZoneInfo: /usr/share/zoneinfo
network interfaces
net:
port: 27018
bindIp: 0.0.0.0
replication:
3. create a service file mongod-standby.service and change the content
Environment=“OPTIONS=-f /etc/mongod-secondary.conf”
PIDFile=/data/mongoDB/mongod-secondary.pid
%mongod ALL = /usr/bin/systemctl * mongod-secondary.service
6. start mongod-standby.service
systemctl start mongod-standby.service
Troubleshoot
openssl rand -base64 741 > /data/mongoDB/mongodb-secondary.key
chmod 600 mongodb-secondary.key
Add in mongod-secondary.conf file:
security:
keyFile: /data/mongoDB/mongodb-secondary.key
Now execute start mongod-secondary.service
7. login to secondary instance
mongo --port 27018 -u “mongoadmin” -p “mongoadmin” --authenticationDatabase “admin”
MongoDB shell version v4.4.8
connecting to: mongodb://127.0.0.1:27018/?authSource=admin&compressors=disabled&gssapiServiceName=mongodb
Error: Authentication failed. :
connect@src/mongo/shell/mongo.js:374:17
@(connect):2:6
exception: connect failed
exiting with code 1
any idea, why i am not able to connect to secondary node although service status is active??
Keyfile should be shared between members
Why create separate keyfile for secondary?
Could be due to this you are unable to authenticate?
Hi @Chinmaya_Das
Is right @Ramachandra_Tummala, the keyfile must be the same among the replica set member.
With keyfile authentication, each mongod instances in the replica set uses the contents of the keyfile as the shared password for authenticating other members in the deployment. Only mongod instances with the correct keyfile can join the replica set.
Also you have to give:
chmod 400 path-to-keyfile
For more details, you can refer to this page:
Update Replica Set to Keyfile Authentication — MongoDB Manual
I hope it can help you,
Best regards.
I used single key file
still same error
-bash-4.2$ mongo --port 27018 -u “mongoadmin” -p “mongoadmin” --authenticationDatabase “admin”
@(connect):2:6
exiting with code 1
secondary instance i am not able connect
Hi @Chinmaya_Das,
show the output of the rs.conf() & the rs.status() command from the primary.
