I have a collection with 500k documents with the following structure:
"_id" : ObjectId("5f2d30b0c7cc16c0da84a57d"),
"RecipientId" : "6a28d20f-4741-4c14-a055-2eb2593dcf13",
"Actions" : [
"CampaignId" : "7fa216da-db22-44a9-9ea3-c987c4152ba1",
"ActionDatetime" : ISODate("1998-01-13T00:00:00.000Z"),
"ActionDescription" : "OPEN"
I need to count the top level documents whose subdocuments inside the “Actions” array meet certain criteria, and for this I’ve created the following Multikey index (taking only the “ActionDatetime” field as an example):
db.getCollection("recipients").createIndex( { "Actions.ActionDatetime": 1 } )
The problem is that when I write the query using an $elemMatch, the operation is much slower than when I don’t use the Multikey index at all:
db.getCollection("recipients").count({
"Actions":
{ $elemMatch:{ ActionDatetime: {$gt: new Date("1950-08-04")} }}}
The stats for this query:
"executionSuccess" : true,
"nReturned" : 0,
"executionTimeMillis" : 13093,
"totalKeysExamined" : 8706602,
"totalDocsExamined" : 500000,
"executionStages" : {
"stage" : "COUNT",
"nReturned" : 0,
"executionTimeMillisEstimate" : 1050,
"works" : 8706603,
"advanced" : 0,
"needTime" : 8706602,
"needYield" : 0,
"saveState" : 68020,
"restoreState" : 68020,
"isEOF" : 1,
"nCounted" : 500000,
"nSkipped" : 0,
"inputStage" : {
"stage" : "FETCH",
"filter" : {
"Actions" : {
"$elemMatch" : {
"ActionDatetime" : {
"$gt" : ISODate("1950-08-04T00:00:00.000Z")
"nReturned" : 500000,
"executionTimeMillisEstimate" : 1040,
"works" : 8706603,
"advanced" : 500000,
"needTime" : 8206602,
"needYield" : 0,
"isEOF" : 1,
"docsExamined" : 500000,
"alreadyHasObj" : 0,
"inputStage" : {
"stage" : "IXSCAN",
"executionTimeMillisEstimate" : 266,
"works" : 8706603,
"needYield" : 0,
"isEOF" : 1,
"keyPattern" : {
"Actions.ActionDatetime" : 1.0
"indexName" : "Actions.ActionDatetime_1",
"isMultiKey" : true,
"multiKeyPaths" : {
"Actions.ActionDatetime" : [
"Actions"
"isUnique" : false,
"isSparse" : false,
"isPartial" : false,
"indexVersion" : 2,
"direction" : "forward",
"indexBounds" : {
"(new Date(-612576000000), new Date(9223372036854775807)]"
"keysExamined" : 8706602,
"seeks" : 1,
"dupsTested" : 8706602,
"dupsDropped" : 8206602
This query took 14sec to execute, whereas if I remove the index, the COLLSCAN takes 1 second.
I understand that I’d have a better performance by not using $elemMatch, and filtering by “Actions.ActionDatetime” directly, but in reality I’ll need to filter by more than one field inside the array, so the $elemMatch becomes mandatory.
I suspect that it’s the FETCH phase which is killing the performance, but I’ve noticed that when i use the “Actions.ActionDatetime” directly, MongoDB is able to use a COUNT_SCAN instead of the fetch, but the performance is still poorer than the COLLSCAN (4s).
I’d like to know if there’s a better indexing strategy for indexing subdocuments with high cardinality inside an array, or if I’m missing something with my current approach.
As the volume grows, indexing this information will be a necessity and I don’t want to rely on a COLLSCAN.
