Basically I have a recursive function that returns an array of results at the end. I’m using an event emitter to return the results .
const parseDirectory = (all, results) => {
if (!all.length) {
return myEmitter.emit('results', results);
My event handler seems to work as far as receiving the results -
myEmitter.on('results', async arr => {
console.log(arr) - // can see results
await music.insertMany(arr).then(result => console.log(result));
What’s happening is the insertions are done but for some weird reason it looks like it’s attempting to do the operation again maybe ? Is there something wrong with the code, seems pretty straight forward to me. I know emitters are generally synchronous but even with asynchronous on it is getting the array correctly.
Perhaps something I need to change in my writeconcern ? currently it’s the default write concern.
