I am building a Vue app.
I followed this
https://docs.mongodb.com/realm/node/install/#node-install
I get this error:
I followed this
I get this error:
Hi Fred – We don’t believe this should be the case and were not able to reproduce. Did you take any steps outside of what is outlined in that documentation page?
Video of steps: https://youtu.be/8sIOGcLiLY0
So the instructions for actually installing Realm for React Native lists the exact same command.
Here is the link :https://docs.mongodb.com/realm/react-native/install/
On this page it has the same instructions: npm install --save realm@10.0.0-beta.6
I am going to assume the NON React instructions should be different. Can anyone provide them?
@Fred_Kufner What are you trying to do? Vue.js is a frontend framework, are you trying to call MongoDB Realm functionality from a browser? If so you need to take a look at this tutorial:
https://docs.mongodb.com/realm/web/quickstart/
We have a warning here on what library to use for which platform:
@Ian_Ward The Web SDK does not work for Vue.
https://www.mongodb.com/community/forums/t/realm-web-sdk-and-vuejs/5527
Understood - have you used the old stitch web sdk in a Vue.js application before? If so you can continue to do so - it appears it will work:
Thanks Ian, Michael. (I recently watched your video “Create a Data API in 10 Minutes with MongoDB Stitch”, it was helpful)
I see that example and its helpful. What is the call to login with API Key instead of using AnonymousCredential()?
