I setup a ReplicaSet (1 Primary and 2 Secondary) via Docker Compose. The ReplicaSet is up. However, the read requests are not getting directed to the secondary nodes. The Primary node seems to be receiving the read requests. I checked the query types for each node using mongostat. The secondary only gets updates as part of the replication step from the Primary. Can anyone please tell me what is causing this behaviour ? I have provided the shell script which I am calling to create the replicaset below
setup.sh:
#!/bin/bash
#MONGODB1=`ping -c 1 mongo1 | head -1 | cut -d "(" -f 2 | cut -d ")" -f 1`
#MONGODB2=`ping -c 1 mongo2 | head -1 | cut -d "(" -f 2 | cut -d ")" -f 1`
#MONGODB3=`ping -c 1 mongo3 | head -1 | cut -d "(" -f 2 | cut -d ")" -f 1`
MONGODB1=mongodb1
MONGODB2=mongodb2
MONGODB3=mongodb3
echo "**********************************************" ${MONGODB1}
echo "Waiting for startup.."
until curl http://${MONGODB1}:27017/serverStatus\?text\=1 2>&1 | grep uptime | head -1; do
printf '.'
sleep 1
done
# echo curl http://${MONGODB1}:27017/serverStatus\?text\=1 2>&1 | grep uptime | head -1
echo ${MONGODB1} " Started.."
echo "**************Replica Set configuration Begin*********"
echo SETUP.sh time now: `date +"%T" `
mongo --host ${MONGODB1}:27017 <<EOF
var cfg = {
"_id": "rs0",
"protocolVersion": 1,
"version": 1,
"members": [
"_id": 0,
"host": "${MONGODB1}:27017",
"priority": 2
"_id": 1,
"host": "${MONGODB2}:27017",
"priority": 0
"_id": 2,
"host": "${MONGODB3}:27017",
"priority": 0
],settings: {chainingAllowed: true}
rs.initiate(cfg, { force: true });
rs.reconfig(cfg, { force: true });
rs.slaveOk();
db.getMongo().setReadPref('secondary');
db.getMongo().setSlaveOk();
echo "**************Replica Set configuration Complete*********"
EOF
until mongo --host ${MONGODB1}:27017 --eval 'db.isMaster().primary' | tail -1 | grep ${MONGODB1}; do
printf 'Waiting for Replica Set to Intialize Primary.....'
sleep 1
done
echo "Primary intialized...."
echo "**************Index Creation Begin*********"
use orion;
db.createCollection("entities");
db.entities.createIndex({"_id.servicePath": 1, "_id.id": 1, "_id.type": 1}, {unique: true});
db.entities.createIndex({"_id.type": 1}); db.entities.createIndex({"_id.id": 1});
use orion-iotteststand;
use iotagentul;
db.createCollection("devices");
db.devices.createIndex({"_id.service": 1, "_id.id": 1, "_id.type": 1});
echo "**************Index Creation Complete*********"
EOF
