In Atlas we are running MongoDB 6.1.1
I have downloaded a backup, and unzip it like usual. On my local computer I have mongod community installed:
mongod --version
db version v6.0.0
Build Info: {
"version": "6.0.0",
"gitVersion": "e61bf27c2f6a83fed36e5a13c008a32d563babe2",
"modules": [],
"allocator": "system",
"environment": {
"distarch": "aarch64",
"target_arch": "aarch64"
When I now try to run the downloaded backup with mongod like this:
mongod --dbpath restore-63c6be85f42181731c9ea998/ --port 58109
I get the following error:
{"t":{"$date":"2023-01-17T21:35:29.462+01:00"},"s":"I", "c":"NETWORK", "id":4915701, "ctx":"-","msg":"Initialized wire specification","attr":{"spec":{"incomingExternalClient":{"minWireVersion":0,"maxWireVersion":17},"incomingInternalClient":{"minWireVersion":0,"maxWireVersion":17},"outgoing":{"minWireVersion":6,"maxWireVersion":17},"isInternalClient":true}}}
{"t":{"$date":"2023-01-17T21:35:29.463+01:00"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"-","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"}
{"t":{"$date":"2023-01-17T21:35:29.465+01:00"},"s":"I", "c":"NETWORK", "id":4648602, "ctx":"main","msg":"Implicit TCP FastOpen in use."}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationDonorService","namespace":"config.tenantMigrationDonors"}}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationRecipientService","namespace":"config.tenantMigrationRecipients"}}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"ShardSplitDonorService","namespace":"config.tenantSplitDonors"}}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"CONTROL", "id":5945603, "ctx":"main","msg":"Multi threading initialized"}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"CONTROL", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":53549,"port":58109,"dbPath":"restore-63c6be85f42181731c9ea998/","architecture":"64-bit","host":"Alexs-Mac-Studio.local"}}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"CONTROL", "id":23352, "ctx":"initandlisten","msg":"Unable to resolve sysctl {sysctlName} (number) ","attr":{"sysctlName":"hw.cpufrequency"}}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"CONTROL", "id":23351, "ctx":"initandlisten","msg":"{sysctlName} unavailable","attr":{"sysctlName":"machdep.cpu.features"}}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"CONTROL", "id":23403, "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"6.0.0","gitVersion":"e61bf27c2f6a83fed36e5a13c008a32d563babe2","modules":[],"allocator":"system","environment":{"distarch":"aarch64","target_arch":"aarch64"}}}}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"CONTROL", "id":51765, "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"Mac OS X","version":"22.2.0"}}}
{"t":{"$date":"2023-01-17T21:35:29.466+01:00"},"s":"I", "c":"CONTROL", "id":21951, "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{"net":{"port":58109},"storage":{"dbPath":"restore-63c6be85f42181731c9ea998/"}}}}
{"t":{"$date":"2023-01-17T21:35:29.467+01:00"},"s":"I", "c":"NETWORK", "id":5693100, "ctx":"initandlisten","msg":"Asio socket.set_option failed with std::system_error","attr":{"note":"acceptor TCP fast open","option":{"level":6,"name":261,"data":"00 04 00 00"},"error":{"what":"set_option: Invalid argument","message":"Invalid argument","category":"asio.system","value":22}}}
{"t":{"$date":"2023-01-17T21:35:29.467+01:00"},"s":"I", "c":"STORAGE", "id":22315, "ctx":"initandlisten","msg":"Opening WiredTiger","attr":{"config":"create,cache_size=32256M,session_max=33000,eviction=(threads_min=4,threads_max=4),config_base=false,statistics=(fast),log=(enabled=true,remove=true,path=journal,compressor=snappy),builtin_extension_config=(zstd=(compression_level=6)),file_manager=(close_idle_time=600,close_scan_interval=10,close_handle_minimum=2000),statistics_log=(wait=0),json_output=(error,message),verbose=[recovery_progress:1,checkpoint_progress:1,compact_progress:1,backup:0,checkpoint:0,compact:0,evict:0,history_store:0,recovery:0,rts:0,salvage:0,tiered:0,timestamp:0,transaction:0,verify:0,log:0],"}}
{"t":{"$date":"2023-01-17T21:35:30.247+01:00"},"s":"I", "c":"STORAGE", "id":4795906, "ctx":"initandlisten","msg":"WiredTiger opened","attr":{"durationMillis":780}}
{"t":{"$date":"2023-01-17T21:35:30.247+01:00"},"s":"I", "c":"RECOVERY", "id":23987, "ctx":"initandlisten","msg":"WiredTiger recoveryTimestamp","attr":{"recoveryTimestamp":{"$timestamp":{"t":1673969429,"i":30}}}}
{"t":{"$date":"2023-01-17T21:35:30.247+01:00"},"s":"I", "c":"RECOVERY", "id":5380106, "ctx":"initandlisten","msg":"WiredTiger oldestTimestamp","attr":{"oldestTimestamp":{"$timestamp":{"t":1673969129,"i":30}}}}
{"t":{"$date":"2023-01-17T21:35:30.251+01:00"},"s":"I", "c":"WT", "id":4366406, "ctx":"initandlisten","msg":"Modifying the table logging settings for all existing WiredTiger tables","attr":{"loggingEnabled":true}}
{"t":{"$date":"2023-01-17T21:35:30.281+01:00"},"s":"I", "c":"STORAGE", "id":22383, "ctx":"initandlisten","msg":"The size storer reports that the oplog contains","attr":{"numRecords":4397065,"dataSize":5373326204}}
{"t":{"$date":"2023-01-17T21:35:30.281+01:00"},"s":"I", "c":"STORAGE", "id":22386, "ctx":"initandlisten","msg":"Sampling the oplog to determine where to place markers for truncation"}
{"t":{"$date":"2023-01-17T21:35:30.281+01:00"},"s":"I", "c":"STORAGE", "id":22389, "ctx":"initandlisten","msg":"Sampling from the oplog to determine where to place markers for truncation","attr":{"from":{"$timestamp":{"t":1664745097,"i":1}},"to":{"$timestamp":{"t":1673969466,"i":1}}}}
{"t":{"$date":"2023-01-17T21:35:30.281+01:00"},"s":"I", "c":"STORAGE", "id":22390, "ctx":"initandlisten","msg":"Taking samples and assuming each oplog section contains","attr":{"numSamples":102,"minBytesPerStone":524288000,"containsNumRecords":429032,"containsNumBytes":524288107}}
{"t":{"$date":"2023-01-17T21:35:30.289+01:00"},"s":"I", "c":"STORAGE", "id":22393, "ctx":"initandlisten","msg":"Oplog sampling complete"}
{"t":{"$date":"2023-01-17T21:35:30.289+01:00"},"s":"I", "c":"STORAGE", "id":22382, "ctx":"initandlisten","msg":"WiredTiger record store oplog processing finished","attr":{"durationMillis":8}}
{"t":{"$date":"2023-01-17T21:35:30.846+01:00"},"s":"W", "c":"CONTROL", "id":22120, "ctx":"initandlisten","msg":"Access control is not enabled for the database. Read and write access to data and configuration is unrestricted","tags":["startupWarnings"]}
{"t":{"$date":"2023-01-17T21:35:30.846+01:00"},"s":"W", "c":"CONTROL", "id":22140, "ctx":"initandlisten","msg":"This server is bound to localhost. Remote systems will be unable to connect to this server. Start the server with --bind_ip <address> to specify which IP addresses it should serve responses from, or with --bind_ip_all to bind to all interfaces. If this behavior is desired, start the server with --bind_ip 127.0.0.1 to disable this warning","tags":["startupWarnings"]}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"F", "c":"CONTROL", "id":20573, "ctx":"initandlisten","msg":"Wrong mongod version","attr":{"error":"UPGRADE PROBLEM: Found an invalid featureCompatibilityVersion document (ERROR: Location4926900: Invalid featureCompatibilityVersion document in admin.system.version: { _id: \"featureCompatibilityVersion\", version: \"6.1\" }. See https://docs.mongodb.com/master/release-notes/5.0-compatibility/#feature-compatibility. :: caused by :: Invalid feature compatibility version value, expected '5.0' or '5.3' or '6.0. See https://docs.mongodb.com/master/release-notes/5.0-compatibility/#feature-compatibility.). If the current featureCompatibilityVersion is below 5.0, see the documentation on upgrading at https://docs.mongodb.com/master/release-notes/5.0/#upgrade-procedures."}}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"REPL", "id":4784900, "ctx":"initandlisten","msg":"Stepping down the ReplicationCoordinator for shutdown","attr":{"waitTimeMillis":15000}}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"REPL", "id":4794602, "ctx":"initandlisten","msg":"Attempting to enter quiesce mode"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"-", "id":6371601, "ctx":"initandlisten","msg":"Shutting down the FLE Crud thread pool"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"COMMAND", "id":4784901, "ctx":"initandlisten","msg":"Shutting down the MirrorMaestro"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"SHARDING", "id":4784902, "ctx":"initandlisten","msg":"Shutting down the WaitForMajorityService"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"NETWORK", "id":20562, "ctx":"initandlisten","msg":"Shutdown: going to close listening sockets"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"NETWORK", "id":4784905, "ctx":"initandlisten","msg":"Shutting down the global connection pool"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"CONTROL", "id":4784906, "ctx":"initandlisten","msg":"Shutting down the FlowControlTicketholder"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"-", "id":20520, "ctx":"initandlisten","msg":"Stopping further Flow Control ticket acquisitions."}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"CONTROL", "id":4784908, "ctx":"initandlisten","msg":"Shutting down the PeriodicThreadToAbortExpiredTransactions"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"REPL", "id":4784909, "ctx":"initandlisten","msg":"Shutting down the ReplicationCoordinator"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"SHARDING", "id":4784910, "ctx":"initandlisten","msg":"Shutting down the ShardingInitializationMongoD"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"REPL", "id":4784911, "ctx":"initandlisten","msg":"Enqueuing the ReplicationStateTransitionLock for shutdown"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"-", "id":4784912, "ctx":"initandlisten","msg":"Killing all operations for shutdown"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"-", "id":4695300, "ctx":"initandlisten","msg":"Interrupted all currently running operations","attr":{"opsKilled":3}}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"TENANT_M", "id":5093807, "ctx":"initandlisten","msg":"Shutting down all TenantMigrationAccessBlockers on global shutdown"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"COMMAND", "id":4784913, "ctx":"initandlisten","msg":"Shutting down all open transactions"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"REPL", "id":4784914, "ctx":"initandlisten","msg":"Acquiring the ReplicationStateTransitionLock for shutdown"}
{"t":{"$date":"2023-01-17T21:35:30.901+01:00"},"s":"I", "c":"INDEX", "id":4784915, "ctx":"initandlisten","msg":"Shutting down the IndexBuildsCoordinator"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"NETWORK", "id":4784918, "ctx":"initandlisten","msg":"Shutting down the ReplicaSetMonitor"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"SHARDING", "id":4784921, "ctx":"initandlisten","msg":"Shutting down the MigrationUtilExecutor"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"ASIO", "id":22582, "ctx":"MigrationUtil-TaskExecutor","msg":"Killing all outstanding egress activity."}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"COMMAND", "id":4784923, "ctx":"initandlisten","msg":"Shutting down the ServiceEntryPoint"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"CONTROL", "id":4784925, "ctx":"initandlisten","msg":"Shutting down free monitoring"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"CONTROL", "id":4784927, "ctx":"initandlisten","msg":"Shutting down the HealthLog"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"CONTROL", "id":4784928, "ctx":"initandlisten","msg":"Shutting down the TTL monitor"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"CONTROL", "id":6278511, "ctx":"initandlisten","msg":"Shutting down the Change Stream Expired Pre-images Remover"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"CONTROL", "id":4784929, "ctx":"initandlisten","msg":"Acquiring the global lock for shutdown"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"CONTROL", "id":4784930, "ctx":"initandlisten","msg":"Shutting down the storage engine"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":22320, "ctx":"initandlisten","msg":"Shutting down journal flusher thread"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":22321, "ctx":"initandlisten","msg":"Finished shutting down journal flusher thread"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":22322, "ctx":"initandlisten","msg":"Shutting down checkpoint thread"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":22323, "ctx":"initandlisten","msg":"Finished shutting down checkpoint thread"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":20282, "ctx":"initandlisten","msg":"Deregistering all the collections"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":22372, "ctx":"OplogVisibilityThread","msg":"Oplog visibility thread shutting down."}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":22317, "ctx":"initandlisten","msg":"WiredTigerKVEngine shutting down"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":22318, "ctx":"initandlisten","msg":"Shutting down session sweeper thread"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":22319, "ctx":"initandlisten","msg":"Finished shutting down session sweeper thread"}
{"t":{"$date":"2023-01-17T21:35:30.902+01:00"},"s":"I", "c":"STORAGE", "id":4795902, "ctx":"initandlisten","msg":"Closing WiredTiger","attr":{"closeConfig":"leak_memory=true,"}}
{"t":{"$date":"2023-01-17T21:35:30.941+01:00"},"s":"I", "c":"STORAGE", "id":4795901, "ctx":"initandlisten","msg":"WiredTiger closed","attr":{"durationMillis":39}}
{"t":{"$date":"2023-01-17T21:35:30.941+01:00"},"s":"I", "c":"STORAGE", "id":22279, "ctx":"initandlisten","msg":"shutdown: removing fs lock..."}
{"t":{"$date":"2023-01-17T21:35:30.941+01:00"},"s":"I", "c":"-", "id":4784931, "ctx":"initandlisten","msg":"Dropping the scope cache for shutdown"}
{"t":{"$date":"2023-01-17T21:35:30.941+01:00"},"s":"I", "c":"CONTROL", "id":20565, "ctx":"initandlisten","msg":"Now exiting"}
{"t":{"$date":"2023-01-17T21:35:30.941+01:00"},"s":"I", "c":"CONTROL", "id":23138, "ctx":"initandlisten","msg":"Shutting down","attr":{"exitCode":62}}
This used to be such a convenient way of running MongoDB backups - but is it impossible now? Please advice
