Using a “songs” collection, and a generic “translations” collection, which can contain translations of documents from other collections.
If I need to recreate some of the “songs” documents (as I am retrieving them from an external api), then the Object_id would change.
In all documentation I see that by design, it’s better to use the Object_id of the document as a reference, but it is volatile. (I have also read that Sharding might change the Object_id).
Why is not a best practice to have our own internal unique ID?
After recreating the songs, I will lose the reference to their translations.
My question is more about the need of creating and maintaining a different unique id to identify documents.
I think there has to be some considerations when best practices are defined, such as:
Are the documents internally generated, or can some of them be generated externally?
Would the documents be shared with external resources?
Do the documents need to be referenced? And what is the impact of losing reference id?
Another case can be when dealing with countries ISO 3166. Parts of a country document can change (an alpha id, a country code, or even the country name). But a change can have a major impact to the application.
In this case, I am also thinking to create my own internal id, so in case a country document changes, I can easily update the document and the impact to the overall application would be low.
But I am quite new in MongoDB, and not sure if this approach is correct, and other smart & experienced people have a well-founded solution.
