Problem with array
Good day, I’ve been scraching my head for a while now. I can’t figure out how to get data from docs in 3 diferent collections:
  1. Document from tentants collection:
  "_id": {
    "$oid": "671802da14d80e976eb4c1dd"
  "date": "2024-10-22T12:00:00",
  "tenant": "NAME OF TENANT",
  "rooms": [
      "TN",
      "N2",
      "201"
      "TN",
      "N3",
      "301"
  "status": "active"
  1. Documents from device_distribution:
  "_id": {
    "$oid": "6717f23c14d80e976eb4c112"
  "line": 1,
  "label": "L1",
  "device": "TN-N2-1",
  "room": "201",
  "level": "N2",
  "building": "TN",
  "_id": {
    "$oid": "6717f23c14d80e976eb4c113"
  "line": 2,
  "label": "L2",
  "room": "201",
  "level": "N2",
  "building": "TN",
  "_id": {
    "$oid": "6717f23c14d80e976eb4c114"
  "line": 3,
  "label": "L3",
  "room": "201",
  "level": "N2",
  "building": "TN",
  1. Documents from records collection:
  "_id": {
    "$oid": "673213c0a9c31e9eb57b53c1"
  "date": "2024-11-11T14:00:00",
  "line": 1,
  "building": "TN",
  "reading": 1.5,
  "connections": 1
  "_id": {
    "$oid": "673213e1a9c31e9eb57b53c3"
  "date": "2024-11-11T23:00:00",
  "line": 1,
  "building": "TN",
  "reading": 2.5,
  "connections": 1
This is what I am trying to achieve using an agregation pipeline:
  1. Get:
  • _id
  • tenant
  • rooms
From collection:
  • tenants
Filter by:
  • _id: ObjectId(“671802da14d80e976eb4c1dd”)
  • status: “active”
  1. Get:
  • line
  • device
  • room
  • level
  • building
From collection:
  • device_distribution
Filter by:
  • building
  • level
  • room <<< Here is where the first problem occures, I need to filter the documents by the info in the rooms array I get from the tenants collection
  1. Get:
  • device
  • line
  • reading
  • connections
From collection:
  • records
Filter by:
  • date (only latest doc from current month and year)
  • device
  • line
I would greatly appreciate for help
What have you tried? Share the aggregation you tried. How did it failed?
Please provide an example of the result that you want.
You could bring more people to work on your issue by creating a playground with your sample documents.
@Vitaly_Abilevich, 8 days ago I took the time to reply your post and asked for more information.
I would appreciate some followup. If you found the solution to your issue please share it in a new post and mark it as the solution.
