Hi guys.
I ran into a problem upon installing the package on Mac.
I’m inside my home directory, new terminal on the file, open nano editor, I copy the directory path, but when I want to save the changes, I get the following error message
[ Error writing etc/paths: No such file or directory ]
Does anyone had the same issue ?
Ok. the path editing worked but now it’s the console part that doesn’t work :
Last login: Tue Aug 4 09:36:47 on ttys000
gaetan@MacBook-Pro-de-Gaetan ~ % mongo --nodb
zsh: command not found: mongo
gaetan@MacBook-Pro-de-Gaetan ~ % exec bash
The default interactive shell is now zsh.
To update your account to use zsh, please run chsh -s /bin/zsh.
For more details, please visit Use zsh as the default shell on your Mac - Apple Support.
bash-3.2$ mongo --nodb
bash: mongo: command not found
bash-3.2$
Ok, I can now run the commands but my Mac prompts a message which says :
Impossible to open “mongo”, developper can’t be verified.
Any ideas ?
All good and running. Thanks anyway ^^
