Mielpops
(Mielpops)
August 1, 2022, 2:47pm
1
Hello
I have model of this type
const projectSchema = new mongoose.Schema({
price: Number,
idCoinMarketCap :Number
I would like to change the price of each project with respect to the following variable
let listePriceId = {
priceId: [
price: 32000,
price: 1700,
price: 3000,
For this I used uptate to Many
exports.configContract = (req, res) => {
Project.updateMany(
$set: {
"price": listePriceId.priceId['$idCoinMarketCap']
(err, response) => {
if (err) return res.status(500).json({ msg: 'update failed', error: err });
res.status(200).json({ msg: `document updated`, response: response },
It doesn’t work unfortunately
Hello @Mielpops ,
For the bulk update you have to use bulkWrite() method, because your every document have own condition/query.
You can use something like this way, I have used updateOne inside bulkWrite(), you can use updateMany if there are multiple matches of idCoinMarketCap field,
exports.configContract = async (req, res) => {
await Project.bulkWrite([
updateOne: {
filter: { idCoinMarketCap: 1 },
update: { price: 32000 }
updateOne: {
filter: { idCoinMarketCap: 2 },
update: { price: 1700 }
updateOne: {
filter: { idCoinMarketCap: 3 },
update: { price: 3000 }
]).then((err, response) => {
res.status(200).json({ msg: `document updated`, response: response });
Note: the above code is not tested, prepared from your input.
Mielpops
(Mielpops)
August 3, 2022, 12:20pm
3
Hello thank you for your reply
In my example I put only 3 values
but I’m going to have hundreds
You can create a payload same as I have created through the loop and pass it to bulkWrite() method.
steevej
(Steeve Juneau)
August 3, 2022, 1:42pm
5
Requirements like
should be stated at the beginning since as you have seen the solutions will vary. Luckily, @turivishal ’s solution is easily adaptable as he mentioned.
An alternative that could be interesting would be:
create a temporary collection with your price_id_list
perform an aggregation what does a $lookup in the price_id_list
use a final $merge stage to update the price
Mielpops
(Mielpops)
August 4, 2022, 7:41pm
6
Hello
thank you both for your answer, I chose the solution of $lookup with $merge.
It works very well, thank you very much
I close the topic
