Problem inserting UUID field with binary subType via Atlas web UI
I have a problem inserting this document in Atlas:
       "provider_id": {
                 "$binary": {
                        "base64":"EEcD/D8V5nFBWgMzZXhlsA==",
                        "subType":"04"
It save to the database with subtype “03”!!!
It must be a typo when you inserted it as I was able to it.
MongoDB Enterprise Sandbox-shard-0:PRIMARY> d
	"provider_id" : {
		"$binary" : {
			"base64" : "EEcD/D8V5nFBWgMzZXhlsA==",
			"subType" : "04"
MongoDB Enterprise Sandbox-shard-0:PRIMARY> db.test.insertOne( d )
	"acknowledged" : true,
	"insertedId" : ObjectId("5e56d55d8ed2e69dc94143e5")
MongoDB Enterprise Sandbox-shard-0:PRIMARY> db.test.find( { "_id" : ObjectId("5e56d55d8ed2e69dc94143e5") } ).pretty()
	"_id" : ObjectId("5e56d55d8ed2e69dc94143e5"),
	"provider_id" : {
		"$binary" : {
			"subType" : "04"
Hy steevej,
sorry, I don’t explain well.
I can’t do it from the portal (INSERT DOCUMENT, button in the image):
from my app and shell, I can.
I understand better. And I could reproduce. Same insert(with extra comment) in Atlas (https://cloud.mongodb.com) gives
	"_id" : ObjectId("5e56f71e0cf72ad66d312c76"),
	"comment" : "insert in atlas portal",
	"provider_id" : BinData(3,"ceYVP/wDRxCwZXhlMwNaQQ==")
In addition, inserting in Compass gives:
	"_id" : ObjectId("5e56f5bc1e8b1832c4edb65f"),
	"comment" : "inserted with Compass",
	"provider_id" : UUID("104703fc-3f15-e671-415a-0333657865b0")
I don’t know what to say. Awaiting an answer with you.
@Rainer_Leon This must be Atlas bug, I can reproduce the problem, when I insert from Atlas Web UI, it inserts it as
        "_id" : ObjectId("5e56fc89f1f42d119bca2302"),
        "provider_id" : BinData(3, "ceYVP/wDRxCwZXhlMwNaQQ==")
When I insert same thing from Studio 3T or Compass I get this
    "_id" : ObjectId("5e56fe213a3725650e75c144"),
    "provider_id" : {
        "$binary" : {
            "subType" : "04"
Did you solve this in the end?
I am trying to export documents that contain UUIDs and then import them back. When I export to json, the UUIDs are turned into Binary Type 00 and mess everything up!
I’ve added a post with all the details about this on StackOverflow: link
