Possible native memory leak on Java 24 + compression zlob or zstd
When use compression over time on java24 + spring boot 3.5.3 application consumes much more RAM then xmx
Hey @Viacheslav_Sedletskyi, would you be able to share a small reproduction that demonstrates the issue you’ve described (including how you’re measuring these increases)?
It sounds like a bug, but having mechanism to verify the issue you’re experiencing will help us validate and address it faster.
