I believe I’ve found a bug related to projection, specifically when you map an array that is a deep descendant of the document root.
Suppose this is my model:
public class DummyContainer
public DummyContainer(IList<Dummy> dummies)
Dummies = dummies;
this.Id = ObjectId.GenerateNewId().ToString();
public string Id { get; private set; }
public IList<Dummy> Dummies { get; private set; }
public class Dummy
public Dummy(string name)
this.Name = name;
public string Name { get; private set; }
An example that works
Let’s say I insert one document of type DummyContainer into an empty collection:
collection.InsertOneAsync(new DummyContainer(new[]
new Dummy("SomeValue1"),
new Dummy("SomeValue2"),
And then I load all documents from that collection, projected into this type:
class DummyContainerWithDummyNames
public string ContainerId { get; set; }
public IEnumerable<string> DummyNames { get; set; }
Here we go:
var dummyNamesByUsingFindAsync = await (await collection.FindAsync(Builders<DummyContainer>.Filter.Empty, new FindOptions<DummyContainer, DummyContainerWithDummyNames> {
Projection = Builders<DummyContainer>.Projection.Expression(x => new DummyContainerWithDummyNames
ContainerId = x.Id,
DummyNames = x.Dummies.Select(d => d.Name)
})).ToListAsync();
var dummyNamesUsingQuery = await collection.AsQueryable()
.Select(x => new DummyContainerWithDummyNames
ContainerId = x.Id,
.ToListAsync();
Result:
Both dummyNamesByUsingFindAsync and dummyNamesUsingQuery contain one document, and in both cases the property DummyNames is populated with ["SomeValue1", "SomeValue2"].
Example that reproduces the bug
Ok, in order to reproduce the bug, we’re gonna wrap the DummyContainer in a DummyContainerWrapper and let this be our root entity:
public class DummyContainerWrapper
public DummyContainerWrapper(DummyContainer container)
Container = container;
public DummyContainer Container { get; private set; }
We’re gonna insert such a document to a new collection:
await collection.InsertOneAsync(new DummyContainerWrapper(new DummyContainer(new[]
And just like before, we’re gonna query the collection for all documents and project them into the same type we used above:
var dummyNamesByUsingFindAsync = await (await collection.FindAsync(Builders<DummyContainerWrapper>.Filter.Empty, new FindOptions<DummyContainerWrapper, DummyContainerWithDummyNames> {
Projection = Builders<DummyContainerWrapper>.Projection.Expression(x => new DummyContainerWithDummyNames
ContainerId = x.Id,
DummyNames = x.Container.Dummies.Select(d => d.Name)
})).ToListAsync();
ContainerId = x.Id,
.ToListAsync();
And this is where we see the bug:
dummyNamesUsingQuery has one element, who’s DummyNames property is an IEnumerable<string> (the concrete type is List<string>) populated with ["SomeValue1", "SomeValue2"].
dummyNamesByUsingFindAsync on the other hand also has one element, but it´s DummyNames property is of type System.Linq.Enumerable.SelectListIterator<MyTestProgram.Dummy, string>, and the values are both null.
I thought I’d post it here first, to check if this is already a known issue, before I open a Jira ticket.
