Hi all,
mongodump tool offers --query parameter which allows to filter data to be dumped.
When using mongorestore thereafter, in some cases some data could be still there (causing duplicate key error) and it’s a good practice to clean them up first, before restoring from the dump. But, mongorestore only offers to drop the whole database before restoring from the dump.
Given I used --query in mongodump, I would also need to clean up data using the same query, before running mongorestore.
Meaning, I can’t drop the whole database, I only want to delete data given the query (for a specific date).
What is the easiest/simplest/most straightforward way to do this clean up?
I used to use:
mongo myhost:myport/myDb --eval “db.myCollection.remove({date: ISODate("${ISODATE}")})”
but the mongo shell is deprecated now, so maybe I need to move to mongosh now?
Thank you for your ideas.
Ivan
