Not sending not required geo coordinates gives MongoServerError: Can’t extract geo keys
Hi.
I have this schema:
new mongoose.Schema({
        type: String,
        required: true
        type: {
            type: String,
            default: 'Point',
            enum: ['Point']
        coordinates: [Number],
        address: String,
        description: String
Location isn’t required, but if I’m sending only a name in my request, I’m getting this error: MongoServerError: Can't extract geo keys:
How do I make location not required?
Thanks!
Figured it out!
In case anyone faces the same error: make sure you don’t have an index on this field, it makes the field required.
Thanks Brother You saved me
