But I am looking for someone with expertise on MongoDB to review the code. The Cadence team doesn’t have any people familiar with it. I am also quite new to this.
I’m not familiar with Cadence, but a helpful starting point would be sharing some pointers on how to run and test your plugin as well as the current state of the code. This is a large changeset and it is not obvious what functionality has been implemented so far. Some of the changed files also seem unrelated (eg /nosqlplugin/cassandra/*) and presumably should be excluded to make the PR easier to review.
It looks like a lot of tests are currently commented out in the PR (eg mongodb_persistence_test.go) and the PR description is Part 1 so I’m curious what the remaining tasks are. Is there an epic or issue(s) describing what will be implemented?
I think the Cadence community should be able to provide some feedback in terms of adherence to their coding conventions and plugin API. Test coverage would help ensure that your plugin is returning the expected results.
Did you have any specific questions about your usage of MongoDB so far?
