Hello @Vikram_Tanwar ,
Welcome to The MongoDB Community Forums!
As of now, the partialFilterExpression applies to the document. It does not apply to which array elements will be indexed, so I don’t believe that having more complex partial filter expression would help you with your current schema design. For reference, please see SERVER-17853.
One possible workaround is to record the primary email in a separate top-level field, maybe in addition to the email marked as primary in the array, see an example below
"username": u1,
primary_email: "u1@email.com",
primary_email_type: "work"
other_emails: [
type: "work",
value: u1_1@email.com,
"username": u2,
primary_email: "u2@email.com",
other_emails: [
type: "work",
value: u2_1@email.com,
type: "work",
value: u2_2@email.com,
Now, let’s try this with an example, I added below documents to my collection
db.collection.insertMany([
"username": "u1",
"primary_email": "u1@email.com",
"primary_email_type": "work",
"other_emails": [
"type": "work",
"value": "u1_1@email.com"
"username": "u2",
"primary_email": "u2@email.com",
"other_emails": [
"type": "work",
"value": "u2_1@email.com"
"type": "work",
"value": "u2_2@email.com"
Now, to validate that the primary_email field is not a duplicate while inserting new data, I used a unique index with a partial filter expression. Here’s an example of how you can create the unique index:
db.collection.createIndex(
{ "primary_email": 1 },
{ unique: true, partialFilterExpression: { primary_email: { $exists: true } } }
This unique index ensures that the primary_email field is unique across the collection only for documents where the field exists. The $exists operator is used in the partial filter expression to match only the documents that have the primary_email field.
With this unique index in place, if you try to insert a new document with a primary_email that already exists, MongoDB will throw a duplicate key error and prevent the insertion.
Note: The unique index will only apply to documents where the primary_email field exists. If you want to ensure uniqueness across all documents, including those where the primary_email field is missing, you can omit the partialFilterExpression option from the index creation command.
Now, let’s run a few test cases to test the uniqueness of the primary_email field:
- Inserting a document with a unique
primary_email:
db.collection.insertOne({
"username": "u3",
"primary_email": "u3@email.com",
"other_emails": []
Expected result: The document should be inserted successfully without any errors.
Output: Result as expected.
- Inserting a document with a duplicate
primary_email:
"username": "u4",
"other_emails": []
Expected result: The insertion should fail with a duplicate key error since the primary_email value already exists in the collection.
- Inserting a document without a
primary_email:
"username": "u5",
"other_emails": []
Expected result: The document should be inserted successfully since the primary_email field is not present, and the unique index only applies to documents where the field exists.
These test cases cover scenarios where the primary_email is unique, where it is a duplicate, and where it is not present. You can modify the values and add more test cases as per your requirements.
Let me know if this helps!
Tarun
