Need help to write a updateOne syntax for my schema
Hi
My schema is like below
	outerArr : [
			outerId : 1,
			innerArr : [
					 { date: '2023-08-1', type: 'Normal'},
					 { date: '2023-08-2', type: 'Normal'},
					 { date: '2023-08-3', type: 'Normal'}
			outerId : 2,
			innerArr : [
			outerId : 3,
			innerArr : [
I want to update multiple sub documents provided in outerId list [1, 2, 3 ] in a document A in a atomic fashion. Either all mentioned outerId should be modified or none.
Hep me to write a update command to change type to “Reserved” for a given date. “2023-08-3” to each of outerId in list.
I have tried
db.xyz.updateOne(
    $and: [
      {"name" : "A"},
      { "outerArr.outerId": { $in: [1, 2, 3] } },
      { "outerArr.innerArr.date": "2023-08-3" },
      { "outerArr.innerArr.type": "Normal" }
    "$set": {
      "outerArr.$[i].innerArr.$[j].type": "Reserved"
    "arrayFilters": [
        "outerArr.outerId": { "$in": [1, 2, 3] }
         "innerArr.date": "2023-08-3"
However this command fails if json is like below. The problem is outerId 2 and 3 matches conditions but not outerId 1. Write should have failed because outerId 1 not matching the query (My expectation), but when i run write succeeds.
How to make it work for outerId 1 AND outerId 2 AND outerId 3 (logical AND among each outerId in list)
	outerArr : [
			outerId : 1,
			innerArr : [
					 { date: '2023-08-3', type: 'Reserved'}
			outerId : 2,
			innerArr : [
			outerId : 3,
			innerArr : [
Please help in writing proper update
Hello @Manjunath_k_s,
The $in operator returns true if the value of the field matches any of the values from the array, same as $or condition,
You can try $all and $elemMatch operators, but you need to specify the separate condition for each outerId.
  • $all operator checks all the provided criteria should match
  • $elemMatch operator checks the provided criteria in each element
  • Here I have created a variable innerArr to reuse the condition.
const innerArr = {
  "$elemMatch": {
    "date": "2023-08-3",
    "type": "Normal"
db.xyz.updateOne(
    "name": "A",
    "outerArr": {
      "$all": [
          "$elemMatch": {
            "outerId": 1,
            "innerArr": innerArr
          "$elemMatch": {
            "outerId": 2,
          "$elemMatch": {
            "outerId": 3,
    "$set": {
    "arrayFilters": [
      { "i.outerId": { "$in": [1, 2, 3] } },
      { "j.date": "2023-08-3" }
Hi Vishal,
Thanks for suggestion.
Is it possible to give the solution you have provided in spring mongodb syntax ? Atleast the query format ?
I don’t know more about spring syntax, so I would suggest you ask a new topic with the java and spring-data-odm tags so the related person will help you.
