Hi All,
I am trying to use $inc operator on some array elements in my documents, but I noticed a peculiar behavior with the query. Can anyone please help me with understand this issue?
I have a document like below:
"nest1" : {
"uniqueId" : "uniqueId",
"isNew" : false,
"range" : [
"token" : null,
"message" : null
"body" : {
"info" : [
"type" : "FacebookUser",
"totalCalls" : 13252.0,
"type" : "TwitterUser",
"totalCalls":15000.0
I want to increment the value of totalCalls in the info array via update.
This is the command 1 that I tried and it works as expected, the TwitterUser element gets incremented
db.getCollection(“MyCollection”).update({ “nest1.isNew”: false, “nest1.uniqueId”: { $in: [ “uniqueId” ] }, “body.info.type”: “TwitterUser” },{$inc:{“body.info.$.totalCalls”:3}});
But I want to add more conditions to the query, this is the command 2 that I tried, note its query has additional “nest1” fields to be queried for, this increment fails and mongo always updates FacebookUser or first element
db.getCollection(“MyCollection”).update({ “nest1.range.token”:null,“nest1.range.message”:null, “Nest1.isNew”: false, “Nest1.uniqueId”: { $in: [ “uniqueId” ] }, “body.info.type”: “TwitterUser” },{$inc:{“body.info.$.totalCalls”:3}});
Is this some bug? or is this expected behavior?
Can anyone please point out whats wrong here?
