Hello,
I tried to deploy a replicaSet in my development environment, but I’m facing a weird problem in my second server.
In my first server, I’m using a Debian 11 and in my second server I’m using Rocky Linux 9.3
This is the conf file from my first server:
# mongod.conf
# for documentation of all options, see:
# http://docs.mongodb.org/manual/reference/configuration-options/
# Where and how to store data.
storage:
dbPath: /var/lib/mongodb
journal:
enabled: true
engine: wiredTiger
wiredTiger:
collectionConfig:
blockCompressor: zstd
# where to write logging data.
systemLog:
destination: file
logAppend: false
logRotate: rename
path: /var/log/mongodb/mongod.log
# network interfaces
net:
port: 27017
bindIpAll: true
# how the process runs
processManagement:
timeZoneInfo: /usr/share/zoneinfo
#security:
security:
authorization: enabled
keyFile: /var/lib/mongodb/file.key
#replication:
replication:
replSetName: devReplicaSet
And this is the conf file from my second server:
# mongod.conf
storage:
journal:
enabled: true
engine: wiredTiger
wiredTiger:
collectionConfig:
systemLog:
destination: file
logAppend: false
logRotate: rename
net:
port: 27017
bindIp: 0.0.0.0
processManagement:
#security
security:
transitionToAuth: true
#replication:
replication:
Both of my keyFiles are with the recommend permissions (chown and chmod):
jose_rocha@lnx-mongodb-dev-001:~$ ls -hla /var/lib/mongodb/file.key
-r-------- 1 mongodb mongodb 1.0K Nov 26 04:26 /var/lib/mongodb/file.key
[jose_rocha@lnx-mongodb-dev-002 ~]$ ls -hla /var/lib/mongodb/file.key
-r--------. 1 mongod mongod 1.0K Nov 26 04:27 /var/lib/mongodb/file.key
Now the weird issue. When I try to start my mongod process at second server, I receive the following error in mongod.log
{"t":{"$date":"2023-11-28T13:47:13.588-03:00"},"s":"I", "c":"ACCESS", "id":20254, "ctx":"main","msg":"Read security file failed","attr":{"error":{"code":30,"codeName":"InvalidPath","errmsg":"error opening file: /var/lib/mongodb/file.key: bad file"}}}
{"t":{"$date":"2023-11-28T13:47:13.588-03:00"},"s":"D1", "c":"ASSERT", "id":23074, "ctx":"main","msg":"User assertion","attr":{"error":"Location5579201: Unable to acquire security key[s]","file":"src/mongo/db/auth/authorization_manager_global.cpp","line":74}}
And the process won’t start, but if I try to start the mongod process using the commandLine, everything work fine, including the replicaSet:
[jose_rocha@lnx-mongodb-dev-002 ~]$ sudo -u mongod /usr/bin/mongod -f /etc/mongod.conf
I’m completely lost here. I sincerely don’t know what else I could look. Any help ?
EDIT
This is the content of mongod.service from the second server:
[Unit]
Description=MongoDB Database Server
Documentation=https://docs.mongodb.org/manual
After=network-online.target
Wants=network-online.target
[Service]
User=mongod
Group=mongod
Environment="OPTIONS=-f /etc/mongod.conf"
Environment="MONGODB_CONFIG_OVERRIDE_NOFORK=1"
EnvironmentFile=-/etc/sysconfig/mongod
ExecStart=/usr/bin/mongod $OPTIONS
RuntimeDirectory=mongodb
# file size
LimitFSIZE=infinity
# cpu time
LimitCPU=infinity
# virtual memory size
LimitAS=infinity
# open files
LimitNOFILE=64000
# processes/threads
LimitNPROC=64000
# locked memory
LimitMEMLOCK=infinity
# total threads (user+kernel)
TasksMax=infinity
TasksAccounting=false
# Recommended limits for mongod as specified in
# https://docs.mongodb.com/manual/reference/ulimit/#recommended-ulimit-settings
[Install]
WantedBy=multi-user.target
