Long time reader first time poster! thanks for all the questions and answers so far.
I have an interesting issue, where a range query avoids the index but a single $gte or $lte will use the multi key index and return in sub-second.
I have setup a basic test that mimics the basic properties of my actual scenario:
"_id": "",
"groupId": "da65de02-35f0-4885-8c67-8b68109cd2a3",
"data": [
"parent": [
"child": {
"intValue": 1,
"dateValue": "2025-01-04T15:14:16.086Z",
"stringValue": "1"
I created 200K records, grouped into two 100K groups, to better represent my data. The data I am using in production is more than 400K for each document so this test does not completely mimic the results but the test is to ensure the index is used.
collection.createIndex(
groupId: 1,
"data.$**": 1,
Then when we run an aggregation on the data as follows:
$match:
groupId: "da65de02-35f0-4885-8c67-8b68109cd2a3",
"data.parent.child.intValue": {
$gte: 1,
$lt: 20
The index is used but the wildcard part of the index is not used at all.
If I remove the range query and change to $gte or $lte then the wildcard index is used (Multi Key Index is now yes in the explain where as before it is no.
$match:
* query: The query in MQL.
groupId:
$lt: 20,
Final Thought
The crazy thing is if I remap the parent object to a new field in the aggregation and then do the additional filter I can get the time down to a more respectable number, however it stil is not ideal and feels very hacky.
$match:
$gte: 0
$project:
newData: "$data.parent"
$unwind:
path: "$newData",
preserveNullAndEmptyArrays: true
$sort:
"newData.child.intValue": 1
$sort:
$match:
"newData.child.intValue": {
$lt: 20
Questions
- Is this expected behaviour?
- Can I optimise this query at all?
- Any suggestions?
Thanks in advance,
