Not able to connect to Mongo DB Atlas Database when using mongoose.connect.
Error –
MongoParseError: Invalid scheme, expected connection string to start with "mongodb://" or "mongodb+srv://"
Code –
import mongoose from "mongoose";
import { DB_NAME } from "../constants.js";
const connectDB = async () => {
try {
const connectionInstance = await mongoose.connect(
`${process.env.MONGODB_URI}/${DB_NAME}`
console.log(`MONGODB CONNECTED !! ${connectionInstance.connection.host}`);
} catch (error) {
console.error(error);
export default connectDB;
And here is my .env file –
PORT = 8000
MONGODB_URL = mongodb+srv://sumit:xxx@cluster0.fgkpmta.mongodb.net/
Please help
Hey @Sumit_Rajak,
Welcome to the MongoDB Community forums
It seems like there might be a couple of issues in your code and configuration.
In the Connection String in .env File - You’ve defined MONGODB_URL , but in your code, you’re trying to use process.env.MONGODB_URI. Make sure these match.
Apart from that there is no declaration of the DB_NAME in your .env file. Also, I’ll recommend to concatenate the URL string properly. For example: use backticks (`) for string interpolation, not quotes.
Here is the formatted code snippet for your reference:
require("dotenv").config(); // Ensure .env file is read
try {
`${process.env.MONGODB_URL}/${DB_NAME}`, // Use process.env.MONGODB_URL
} catch (error) {
I hope it helps!
Best regards,
Kushagra
Hello,
I modified and changed the MONGODB_URL in my .env to MONGODB_URI.
Still getting the same error.
Here is my code –
import mongoose from “mongoose”;
import { DB_NAME } from “…/constants.js”;
import dotenv from “dotenv”;
dotenv.config({
path: “/.env”,
try {
${process.env.MONGODB_URI}/${DB_NAME}, // Use process.env.MONGODB_URL
console.log(MONGODB CONNECTED !! ${connectionInstance.connection.host});
} catch (error) {
Hello,
I have fixed the error.
The error was my .env file was not loading cause i gave the wrong path.
Thank you so much for the help.
