Repair command
sudo mongod --dbpath /var/lib/mongodb --repair
{“t”:{“$date”:“2022-03-20T18:05:11.071+00:00”},“s”:“W”, “c”:“STORAGE”, “id”:22350, “ctx”:“initandlisten”,“msg”:“Data file is missing. Attempting to drop and re-create the collection.”,“attr”:{“uri”:“table:_mdb_catalog”}} {“t”:{“$date”:“2022-03-20T18:05:11.071+00:00”},“s”:“W”, “c”:“STORAGE”, “id”:22353, “ctx”:“initandlisten”,“msg”:“Rebuilding ident”,“attr”:{“ident”:“_mdb_catalog”}} {“t”:{“$date”:“2022-03-20T18:05:11.072+00:00”},“s”:“E”, “c”:“STORAGE”, “id”:22435, “ctx”:“initandlisten”,“msg”:“WiredTiger error”,“attr”:{“error”:-31803,“message”:“[1647799511:72009][2120:0x7f6984658cc0], file:WiredTiger.wt, WT_CURSOR.search: __schema_source_config, 50: metadata information for source configuration "file:_mdb_catalog.wt" not found: WT_NOTFOUND: item not found”}}
“error”:{“code”:4,“codeName”:“NoSuchKey”,“errmsg”:“Unable to find metadata for table:_mdb_catalog”}}} {“t”:{“$date”:“2022-03-20T17:55:17.150+00:00”}
Mongo Start Command
“msg”:“An incomplete repair has been detected! This is likely because a repair operation unexpectedly failed before completing. MongoDB will not start up again without --repair.”
