Host and port given is wrong ?
Mongodb is not start up at the host and port provided
It actually worked fine for me.
Are you able to confirm that you’re not behind a firewall and can make connections outgoing to 27017?
If not I suggest you copy/paste the address etc to make sure you have them correct.
Hope that helps.
i still facing the same issue.
i did try to ping to the server provided. It show me as below
as well as i did on this, as below
Any updates on this issue ?
Hi Kenth_31619,
Sorry for late response.
Here are some checks you can do to make sure everything is right!
Are you on the latest version of Compass i.e 1.16.1 ? If not, download it here
Try connecting to our cluster through mongo shell. I am assuming you have mongo installed, if not install MongoDB enterprise edition here
Run mongo command from your command line:
mongo “mongodb://cluster0-shard-00-00-jxeqq.mongodb.net:27017,cluster0-shard-00-01-jxeqq.mongodb.net:27017,cluster0-shard-00-02-jxeqq.mongodb.net:27017/test?replicaSet=Cluster0-shard-0” --authenticationDatabase admin --ssl --username m001-student --password m001-mongodb-basics
Let me know if it works!
Kanika
Hi Kenth_31619,
Seems like your network is blocking the requests. Make sure by doing ping cluster0-shard-00-00-jxeqq.mongodb.net.
Also, for details, check here.
Kanika
Have you tried telnet and everything else?
Screen Shot 2018-10-16 at 3.08.28 PM.png1352x862 121 KB
~$ telnet cluster0-shard-00-00-jxeqq.mongodb.net 27017
Trying 34.195.121.130...
Connected to ec2-34-195-121-130.compute-1.amazonaws.com.
If you have, please copy/paste this command directly and wait for it to connect:
Also check for double quotes if you get any syntax error or so.
Kanika
Yes MongoShell works for me, not COMPASS
