{"t":{"$date":"2023-07-02T20:37:23.863+09:00"},"s":"I", "c":"NETWORK", "id":4915701, "ctx":"thread2","msg":"Initialized wire specification","attr":{"spec":{"incomingExternalClient":{"minWireVersion":0,"maxWireVersion":17},"incomingInternalClient":{"minWireVersion":0,"maxWireVersion":17},"outgoing":{"minWireVersion":6,"maxWireVersion":17},"isInternalClient":true}}}
{"t":{"$date":"2023-07-02T20:37:23.873+09:00"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"thread2","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"}
{"t":{"$date":"2023-07-02T20:37:23.874+09:00"},"s":"I", "c":"NETWORK", "id":4648602, "ctx":"thread2","msg":"Implicit TCP FastOpen in use."}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"thread2","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationDonorService","namespace":"config.tenantMigrationDonors"}}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"thread2","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationRecipientService","namespace":"config.tenantMigrationRecipients"}}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"thread2","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"ShardSplitDonorService","namespace":"config.tenantSplitDonors"}}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"CONTROL", "id":5945603, "ctx":"thread2","msg":"Multi threading initialized"}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"CONTROL", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":75751,"port":27017,"dbPath":"/data/db","architecture":"64-bit","host":"sagwakeompyuteo.local"}}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"CONTROL", "id":23352, "ctx":"initandlisten","msg":"Unable to resolve sysctl {sysctlName} (number) ","attr":{"sysctlName":"hw.cpufrequency"}}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"CONTROL", "id":23351, "ctx":"initandlisten","msg":"{sysctlName} unavailable","attr":{"sysctlName":"machdep.cpu.features"}}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"CONTROL", "id":23403, "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"6.0.6","gitVersion":"26b4851a412cc8b9b4a18cdb6cd0f9f642e06aa7","modules":[],"allocator":"system","environment":{"distarch":"aarch64","target_arch":"aarch64"}}}}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"CONTROL", "id":51765, "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"Mac OS X","version":"22.5.0"}}}
{"t":{"$date":"2023-07-02T20:37:23.876+09:00"},"s":"I", "c":"CONTROL", "id":21951, "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{}}}
{"t":{"$date":"2023-07-02T20:37:23.877+09:00"},"s":"I", "c":"NETWORK", "id":5693100, "ctx":"initandlisten","msg":"Asio socket.set_option failed with std::system_error","attr":{"note":"acceptor TCP fast open","option":{"level":6,"name":261,"data":"00 04 00 00"},"error":{"what":"set_option: Invalid argument","message":"Invalid argument","category":"asio.system","value":22}}}
{"t":{"$date":"2023-07-02T20:37:23.877+09:00"},"s":"E", "c":"CONTROL", "id":20568, "ctx":"initandlisten","msg":"Error setting up listener","attr":{"error":{"code":9001,"codeName":"SocketException","errmsg":"Address already in use"}}}
{"t":{"$date":"2023-07-02T20:37:23.877+09:00"},"s":"I", "c":"REPL", "id":4784900, "ctx":"initandlisten","msg":"Stepping down the ReplicationCoordinator for shutdown","attr":{"waitTimeMillis":15000}}
{"t":{"$date":"2023-07-02T20:37:23.878+09:00"},"s":"I", "c":"REPL", "id":4794602, "ctx":"initandlisten","msg":"Attempting to enter quiesce mode"}
{"t":{"$date":"2023-07-02T20:37:23.878+09:00"},"s":"I", "c":"-", "id":6371601, "ctx":"initandlisten","msg":"Shutting down the FLE Crud thread pool"}
{"t":{"$date":"2023-07-02T20:37:23.878+09:00"},"s":"I", "c":"COMMAND", "id":4784901, "ctx":"initandlisten","msg":"Shutting down the MirrorMaestro"}
{"t":{"$date":"2023-07-02T20:37:23.878+09:00"},"s":"I", "c":"SHARDING", "id":4784902, "ctx":"initandlisten","msg":"Shutting down the WaitForMajorityService"}
{"t":{"$date":"2023-07-02T20:37:23.878+09:00"},"s":"I", "c":"NETWORK", "id":4784905, "ctx":"initandlisten","msg":"Shutting down the global connection pool"}
{"t":{"$date":"2023-07-02T20:37:23.878+09:00"},"s":"I", "c":"NETWORK", "id":4784918, "ctx":"initandlisten","msg":"Shutting down the ReplicaSetMonitor"}
{"t":{"$date":"2023-07-02T20:37:23.878+09:00"},"s":"I", "c":"SHARDING", "id":4784921, "ctx":"initandlisten","msg":"Shutting down the MigrationUtilExecutor"}
{"t":{"$date":"2023-07-02T20:37:23.878+09:00"},"s":"I", "c":"ASIO", "id":22582, "ctx":"MigrationUtil-TaskExecutor","msg":"Killing all outstanding egress activity."}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"COMMAND", "id":4784923, "ctx":"initandlisten","msg":"Shutting down the ServiceEntryPoint"}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"CONTROL", "id":4784925, "ctx":"initandlisten","msg":"Shutting down free monitoring"}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"CONTROL", "id":4784927, "ctx":"initandlisten","msg":"Shutting down the HealthLog"}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"CONTROL", "id":4784928, "ctx":"initandlisten","msg":"Shutting down the TTL monitor"}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"CONTROL", "id":6278511, "ctx":"initandlisten","msg":"Shutting down the Change Stream Expired Pre-images Remover"}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"CONTROL", "id":4784929, "ctx":"initandlisten","msg":"Acquiring the global lock for shutdown"}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"-", "id":4784931, "ctx":"initandlisten","msg":"Dropping the scope cache for shutdown"}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"CONTROL", "id":20565, "ctx":"initandlisten","msg":"Now exiting"}
{"t":{"$date":"2023-07-02T20:37:23.879+09:00"},"s":"I", "c":"CONTROL", "id":23138, "ctx":"initandlisten","msg":"Shutting down","attr":{"exitCode":48}}
I can’t run mongodb with those codes.
> wetube@1.0.0 dev
> nodemon --exec babel-node src/init.js
[nodemon] 2.0.22
[nodemon] to restart at any time, enter `rs`
[nodemon] watching path(s): *.*
[nodemon] watching extensions: js,mjs,json
[nodemon] starting `babel-node src/init.js`
✅ Server is listening!
✅ Connected to DB!
undefined
GET / 304 104.595 ms - -
GET /videos/upload 200 29.552 ms - 732
in npm, says succesfully connected to DB.
I can’t find any solutions on google, mongoDB docs, etc. communities…
Please help me…
