I try to move my data e.G: from attribute “attr1” to “subdocument.attribute1” but can’t find a query to do so.
E.G. I try to copy sampleData2 into a new attribute called sampleData3, if the attribute sampleData2 exists.
"sampleData": 123,
"sampleData2": 1234,
"sampleData": 123
I tried this query:
db.collection.update({ "sampleData2": { $exists: true }},{ $set: { sampleData3: "$sampleData2" }})
but the resulting value is “sampleData3” : “$sampleData2” whereas “sampleData3” : 1234 was expected.
Here the sample in the playground
Hello,
Please note that starting 4.2 you can use aggregation pipelines for updates and the use $set is supported.
I checked the snippet you shared and I see $set is not enclosed in which makes it a pipeline.
Please check the example below which I tested in my environment showing the correct value of $sampleData2 being assigned instead of the literal value:
MongoDB Enterprise M040:PRIMARY> db.products.insertOne({"sampleData2":123})
"acknowledged" : true,
"insertedId" : ObjectId("63613bf818cb6cb9c0c2fb4a")
MongoDB Enterprise M040:PRIMARY> db.products.find()
{ "_id" : ObjectId("63613bf818cb6cb9c0c2fb4a"), "sampleData2" : 123 }
MongoDB Enterprise M040:PRIMARY> db.products.update({ "sampleData2": { $exists: true }},[{$set: {"sampleData3": "$sampleData2"}}])
WriteResult({ "nMatched" : 1, "nUpserted" : 0, "nModified" : 1 })
{ "_id" : ObjectId("63613bf818cb6cb9c0c2fb4a"), "sampleData2" : 123, "sampleData3" : 123 }
Please also check to the different aggregation pipeline stages you can use for updates in this documentation link .
I hope you find this helpful.
Mohamed Elshafey
You are a live saver. Thanks so much.
system
(system)
Closed
November 6, 2022, 3:44pm
4
