Lets say I have a collection with documents that looks like this
_id:
list1:
list2:
other:
I can have a bunch of list, in some document I have 2 and in others up to 10. Is there a way I can query with a projection so I only have list1, up to listX but not every other fields? I tried a lot of different aggregate using a regex but so far got no luck.
Thank you!
Hi Robert,
I tried this idea in my testing environment, please check if the below achieves your goal:
// sample documents with different number of field starting with list and also added other fields
db.testregex.find()
_id: ObjectId("6582f2f0978e9e79b39b63a6"),
list1: 1,
list2: 2,
another: 'another text'
_id: ObjectId("6582f2fa978e9e79b39b63a7"),
list1: 1,
list2: 2,
list3: 3,
I executed the below aggregation based on the regex ^list:
db.testregex.aggregate([
... $project: {
... filteredFields: {
... $arrayToObject: {
... $filter: {
... input: { $objectToArray: "$$ROOT" },
... as: "field",
... cond: { $regexMatch: { input: "$$field.k", regex: '^list' } }
filteredFields: { list1: 1, list2: 2 }
filteredFields: { list1: 1, list2: 2, list3: 3 }
Mohamed Elshafey
Hi Mohamed!
Thank you for your reply. This works pretty good.
Is there any way to have the output more something like this? Or do I have to use the filteredFields?
list1: 1,
list2: 2
Thank you in advance
