Our Mongo
- First, our collection ( name it
XY) has more than ~3m documents. - The documents are mostly consistent, complex and nested.
- All documents have these fields >
{X: <str>}, Y: <datetime> - There is
{X: 1, Y: 1}index on the collection
What we want
- want to fetch for a big date range ( more than a year ) where most cases of
Xconsist of thousands documents
Problem:
The query is simple > {X: <str>, Y: {$gte: <datetime>, $lte: <datetime>}}
But, when it runs, the results only come after long time that means 30-40 seconds or more.
According to the explain the query uses the index >
( copied from my company, that’s why somewhere I just replaced the values, for instance epoch )
'winningPlan': {
'stage': 'FETCH', 'inputStage': {
'stage': 'IXSCAN',
'keyPattern': {'X': 1, 'Y': 1},
'indexName': 'XY',
'isMultiKey': False,
'multiKeyPaths': {'X': [], 'Y': []},
'isUnique': False,
'isSparse': False
'isPartial': False
'indexVersion': 2
'direction': 'forward'
'indexBounds': {'X': ['["abc", "abc"]'], 'Y': ['(new Date(<epoch>), new Date(<epoch>))']}
The results of explain was copied from python, and we’ve arrived to the main point of the issue.
For take all documents in one’s stride, in the code we use the built-in list method like this: list(<cursor>). But the query breaks because reaches the SSL connection timeout threshold.
According to the count, the results should be 16k documents, but that retrieves so slow…
What can we do? Could you please give advice, suggestions about issue?
Thanks for your attention in advance.
