Hello, I’m starting to use MongoDB Community server with python…
I try to install it on macOS Catalina, but I met some problems… I try to install it various times, I didn’t succeed.
his is the error that comes back to me when I type “mongod” in the terminal:
*{"t":{"$date":"2020-11-12T17:10:10.293+01:00"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"main","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"}*
*{"t":{"$date":"2020-11-12T17:10:10.298+01:00"},"s":"W", "c":"ASIO", "id":22601, "ctx":"main","msg":"No TransportLayer configured during NetworkInterface startup"}*
*{"t":{"$date":"2020-11-12T17:10:10.299+01:00"},"s":"I", "c":"NETWORK", "id":4648602, "ctx":"main","msg":"Implicit TCP FastOpen in use."}*
*{"t":{"$date":"2020-11-12T17:10:10.299+01:00"},"s":"I", "c":"STORAGE", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":30094,"port":27017,"dbPath":"/data/db","architecture":"64-bit","host":"Cristianos-MacBook-Air.local"}}*
*{"t":{"$date":"2020-11-12T17:10:10.299+01:00"},"s":"I", "c":"CONTROL", "id":23403, "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"4.4.1","gitVersion":"ad91a93a5a31e175f5cbf8c69561e788bbc55ce1","modules":[],"allocator":"system","environment":{"distarch":"x86_64","target_arch":"x86_64"}}}}*
*{"t":{"$date":"2020-11-12T17:10:10.299+01:00"},"s":"I", "c":"CONTROL", "id":51765, "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"Mac OS X","version":"19.6.0"}}}*
*{"t":{"$date":"2020-11-12T17:10:10.299+01:00"},"s":"I", "c":"CONTROL", "id":21951, "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{}}}*
*{"t":{"$date":"2020-11-12T17:10:10.300+01:00"},"s":"E", "c":"NETWORK", "id":23024, "ctx":"initandlisten","msg":"Failed to unlink socket file","attr":{"path":"/tmp/mongodb-27017.sock","error":"Permission denied"}}*
*{"t":{"$date":"2020-11-12T17:10:10.300+01:00"},"s":"F", "c":"-", "id":23091, "ctx":"initandlisten","msg":"Fatal assertion","attr":{"msgid":40486,"file":"src/mongo/transport/transport_layer_asio.cpp","line":919}}*
*{"t":{"$date":"2020-11-12T17:10:10.300+01:00"},"s":"F", "c":"-", "id":23092, "ctx":"initandlisten","msg":"\n\n***aborting after fassert() failure\n\n"}*
After modifying the dpath with the path, “/ System / Volumes / Data / data / db”, obviously having created the folder, “/ data / db”.
could you help me, I also accept alternative installations.
Thank you.
