I have a collection of document with following way
{ _id : XXXXXX, history: [ { "amount" : 10, "date" : ISODate("2023-05-02T15:47:51.805+05:30"), } ], refund_history: [ { "amount" : 10, "date" : ISODate("2023-05-02T15:47:51.805+05:30"), } ], status : "A" }
I want to query
'$or': [ { history : { $ne: [ ] } }, { refund_history : { $ne: [ ] } }]
eventhough i have index on “history” and “refund_history” my query is super slow. please help me identify why my indexing is not working for “not equals case”. if it helps below is the index info i could gather.
history index
{ "v" : 2, "key" : { "history" : 1 }, "name" : "history_1", "indexSize" : 8621916160, "usage stats" : [ { "name" : "history_1", "key" : { "history" : 1 }, "host" : "emp1-PC:27017", "accesses" : { "ops" : 0, "since" : ISODate("2023-05-02T14:20:17.047+05:30") }, "spec" : { "v" : 2, "key" : { "history" : 1 }, "name" : "history_1" } } ], "index details" : { "metadata" : { "formatVersion" : 8 }, "creationString" : "access_pattern_hint=none,allocation_size=4KB,app_metadata=(formatVersion=8),assert=(commit_timestamp=none,durable_timestamp=none,read_timestamp=none,write_timestamp=off),block_allocation=best,block_compressor=,cache_resident=false,checksum=on,colgroups=,collator=,columns=,dictionary=0,encryption=(keyid=,name=),exclusive=false,extractor=,format=btree,huffman_key=,huffman_value=,ignore_in_memory_cache_size=false,immutable=false,import=(compare_timestamp=oldest_timestamp,enabled=false,file_metadata=,metadata_file=,repair=false),internal_item_max=0,internal_key_max=0,internal_key_truncate=true,internal_page_max=16k,key_format=u,key_gap=10,leaf_item_max=0,leaf_key_max=0,leaf_page_max=16k,leaf_value_max=0,log=(enabled=true),lsm=(auto_throttle=true,bloom=true,bloom_bit_count=16,bloom_config=,bloom_hash_count=8,bloom_oldest=false,chunk_count_limit=0,chunk_max=5GB,chunk_size=10MB,merge_custom=(prefix=,start_generation=0,suffix=),merge_max=15,merge_min=0),memory_page_image_max=0,memory_page_max=5MB,os_cache_dirty_max=0,os_cache_max=0,prefix_compression=true,prefix_compression_min=4,readonly=false,source=,split_deepen_min_child=0,split_deepen_per_child=0,split_pct=90,tiered_object=false,tiered_storage=(auth_token=,bucket=,bucket_prefix=,cache_directory=,local_retention=300,name=,object_target_size=0),type=file,value_format=u,verbose=[],write_timestamp_usage=none", "type" : "file", "uri" : "statistics:table:index-18--4789062642330656730", "LSM" : { "bloom filter false positives" : 0, "bloom filter hits" : 0, "bloom filter misses" : 0, "bloom filter pages evicted from cache" : 0, "bloom filter pages read into cache" : 0, "bloom filters in the LSM tree" : 0, "chunks in the LSM tree" : 0, "highest merge generation in the LSM tree" : 0, "queries that could have benefited from a Bloom filter that did not exist" : 0, "sleep for LSM checkpoint throttle" : 0, "sleep for LSM merge throttle" : 0, "total size of bloom filters" : 0 }, "block-manager" : { "allocations requiring file extension" : 0, "blocks allocated" : 0, "blocks freed" : 0, "checkpoint size" : 8621899776, "file allocation unit size" : 4096, "file bytes available for reuse" : 0, "file magic number" : 120897, "file major version number" : 1, "file size in bytes" : 8621916160, "minor version number" : 0 }, "btree" : { "btree checkpoint generation" : 0, "btree clean tree checkpoint expiration time" : 0, "btree compact pages reviewed" : 0, "btree compact pages rewritten" : 0, "btree compact pages skipped" : 0, "btree skipped by compaction as process would not reduce size" : 0, "column-store fixed-size leaf pages" : 0, "column-store fixed-size time windows" : 0, "column-store internal pages" : 0, "column-store variable-size RLE encoded values" : 0, "column-store variable-size deleted values" : 0, "column-store variable-size leaf pages" : 0, "fixed-record size" : 0, "maximum internal page size" : 16384, "maximum leaf page key size" : 1474, "maximum leaf page size" : 16384, "maximum leaf page value size" : 7372, "maximum tree depth" : 0, "number of key/value pairs" : 0, "overflow pages" : 0, "row-store empty values" : 0, "row-store internal pages" : 0, "row-store leaf pages" : 0 }, "cache" : { "bytes currently in the cache" : 4002, "bytes dirty in the cache cumulative" : 0, "bytes read into cache" : 75479, "bytes written from cache" : 0, "checkpoint blocked page eviction" : 0, "checkpoint of history store file blocked non-history store page eviction" : 0, "data source pages selected for eviction unable to be evicted" : 0, "eviction gave up due to detecting an out of order on disk value behind the last update on the chain" : 0, "eviction gave up due to detecting an out of order tombstone ahead of the selected on disk update" : 0, "eviction gave up due to detecting an out of order tombstone ahead of the selected on disk update after validating the update chain" : 0, "eviction gave up due to detecting out of order timestamps on the update chain after the selected on disk update" : 0, "eviction gave up due to needing to remove a record from the history store but checkpoint is running" : 0, "eviction walk passes of a file" : 0, "eviction walk target pages histogram - 0-9" : 0, "eviction walk target pages histogram - 10-31" : 0, "eviction walk target pages histogram - 128 and higher" : 0, "eviction walk target pages histogram - 32-63" : 0, "eviction walk target pages histogram - 64-128" : 0, "eviction walk target pages reduced due to history store cache pressure" : 0, "eviction walks abandoned" : 0, "eviction walks gave up because they restarted their walk twice" : 0, "eviction walks gave up because they saw too many pages and found no candidates" : 0, "eviction walks gave up because they saw too many pages and found too few candidates" : 0, "eviction walks reached end of tree" : 0, "eviction walks restarted" : 0, "eviction walks started from root of tree" : 0, "eviction walks started from saved location in tree" : 0, "hazard pointer blocked page eviction" : 0, "history store table insert calls" : 0, "history store table insert calls that returned restart" : 0, "history store table out-of-order resolved updates that lose their durable timestamp" : 0, "history store table out-of-order updates that were fixed up by reinserting with the fixed timestamp" : 0, "history store table reads" : 0, "history store table reads missed" : 0, "history store table reads requiring squashed modifies" : 0, "history store table truncation by rollback to stable to remove an unstable update" : 0, "history store table truncation by rollback to stable to remove an update" : 0, "history store table truncation to remove an update" : 0, "history store table truncation to remove range of updates due to key being removed from the data page during reconciliation" : 0, "history store table truncation to remove range of updates due to out-of-order timestamp update on data page" : 0, "history store table writes requiring squashed modifies" : 0, "in-memory page passed criteria to be split" : 0, "in-memory page splits" : 0, "internal pages evicted" : 0, "internal pages split during eviction" : 0, "leaf pages split during eviction" : 0, "modified pages evicted" : 0, "overflow pages read into cache" : 0, "page split during eviction deepened the tree" : 0, "page written requiring history store records" : 0, "pages read into cache" : 6, "pages read into cache after truncate" : 0, "pages read into cache after truncate in prepare state" : 0, "pages requested from the cache" : 0, "pages seen by eviction walk" : 0, "pages written from cache" : 0, "pages written requiring in-memory restoration" : 0, "the number of times full update inserted to history store" : 0, "the number of times reverse modify inserted to history store" : 0, "tracked dirty bytes in the cache" : 0, "unmodified pages evicted" : 0 }, "cache_walk" : { "Average difference between current eviction generation when the page was last considered" : 0, "Average on-disk page image size seen" : 0, "Average time in cache for pages that have been visited by the eviction server" : 0, "Average time in cache for pages that have not been visited by the eviction server" : 0, "Clean pages currently in cache" : 0, "Current eviction generation" : 0, "Dirty pages currently in cache" : 0, "Entries in the root page" : 0, "Internal pages currently in cache" : 0, "Leaf pages currently in cache" : 0, "Maximum difference between current eviction generation when the page was last considered" : 0, "Maximum page size seen" : 0, "Minimum on-disk page image size seen" : 0, "Number of pages never visited by eviction server" : 0, "On-disk page image sizes smaller than a single allocation unit" : 0, "Pages created in memory and never written" : 0, "Pages currently queued for eviction" : 0, "Pages that could not be queued for eviction" : 0, "Refs skipped during cache traversal" : 0, "Size of the root page" : 0, "Total number of pages currently in cache" : 0 }, "checkpoint-cleanup" : { "pages added for eviction" : 0, "pages removed" : 0, "pages skipped during tree walk" : 0, "pages visited" : 0 }, "compression" : { "compressed page maximum internal page size prior to compression" : 16384, "compressed page maximum leaf page size prior to compression " : 16384, "compressed pages read" : 0, "compressed pages written" : 0, "number of blocks with compress ratio greater than 64" : 0, "number of blocks with compress ratio smaller than 16" : 0, "number of blocks with compress ratio smaller than 2" : 0, "number of blocks with compress ratio smaller than 32" : 0, "number of blocks with compress ratio smaller than 4" : 0, "number of blocks with compress ratio smaller than 64" : 0, "number of blocks with compress ratio smaller than 8" : 0, "page written failed to compress" : 0, "page written was too small to compress" : 0 }, "cursor" : { "Total number of entries skipped by cursor next calls" : 0, "Total number of entries skipped by cursor prev calls" : 0, "Total number of entries skipped to position the history store cursor" : 0, "Total number of times a search near has exited due to prefix config" : 0, "bulk loaded cursor insert calls" : 0, "cache cursors reuse count" : 0, "close calls that result in cache" : 0, "create calls" : 0, "cursor next calls that skip due to a globally visible history store tombstone" : 0, "cursor next calls that skip greater than or equal to 100 entries" : 0, "cursor next calls that skip less than 100 entries" : 0, "cursor prev calls that skip due to a globally visible history store tombstone" : 0, "cursor prev calls that skip greater than or equal to 100 entries" : 0, "cursor prev calls that skip less than 100 entries" : 0, "insert calls" : 0, "insert key and value bytes" : 0, "modify" : 0, "modify key and value bytes affected" : 0, "modify value bytes modified" : 0, "next calls" : 0, "open cursor count" : 0, "operation restarted" : 0, "prev calls" : 0, "remove calls" : 0, "remove key bytes removed" : 0, "reserve calls" : 0, "reset calls" : 0, "search calls" : 0, "search history store calls" : 0, "search near calls" : 0, "truncate calls" : 0, "update calls" : 0, "update key and value bytes" : 0, "update value size change" : 0 }, "reconciliation" : { "approximate byte size of timestamps in pages written" : 0, "approximate byte size of transaction IDs in pages written" : 0, "dictionary matches" : 0, "fast-path pages deleted" : 0, "internal page key bytes discarded using suffix compression" : 0, "internal page multi-block writes" : 0, "leaf page key bytes discarded using prefix compression" : 0, "leaf page multi-block writes" : 0, "leaf-page overflow keys" : 0, "maximum blocks required for a page" : 0, "overflow values written" : 0, "page checksum matches" : 0, "page reconciliation calls" : 0, "page reconciliation calls for eviction" : 0, "pages deleted" : 0, "pages written including an aggregated newest start durable timestamp " : 0, "pages written including an aggregated newest stop durable timestamp " : 0, "pages written including an aggregated newest stop timestamp " : 0, "pages written including an aggregated newest stop transaction ID" : 0, "pages written including an aggregated newest transaction ID " : 0, "pages written including an aggregated oldest start timestamp " : 0, "pages written including an aggregated prepare" : 0, "pages written including at least one prepare" : 0, "pages written including at least one start durable timestamp" : 0, "pages written including at least one start timestamp" : 0, "pages written including at least one start transaction ID" : 0, "pages written including at least one stop durable timestamp" : 0, "pages written including at least one stop timestamp" : 0, "pages written including at least one stop transaction ID" : 0, "records written including a prepare" : 0, "records written including a start durable timestamp" : 0, "records written including a start timestamp" : 0, "records written including a start transaction ID" : 0, "records written including a stop durable timestamp" : 0, "records written including a stop timestamp" : 0, "records written including a stop transaction ID" : 0 }, "session" : { "object compaction" : 0, "tiered operations dequeued and processed" : 0, "tiered operations scheduled" : 0, "tiered storage local retention time (secs)" : 0 }, "transaction" : { "race to read prepared update retry" : 0, "rollback to stable history store records with stop timestamps older than newer records" : 0, "rollback to stable inconsistent checkpoint" : 0, "rollback to stable keys removed" : 0, "rollback to stable keys restored" : 0, "rollback to stable restored tombstones from history store" : 0, "rollback to stable restored updates from history store" : 0, "rollback to stable skipping delete rle" : 0, "rollback to stable skipping stable rle" : 0, "rollback to stable sweeping history store keys" : 0, "rollback to stable updates removed from history store" : 0, "transaction checkpoints due to obsolete pages" : 0, "update conflicts" : 0 } } }
_________________________________-
refund history index info
{ "v" : 2, "key" : { "refund_history" : 1 }, "name" : "refund_history_1", "indexSize" : 57372672, "usage stats" : [ { "name" : "refund_history_1", "key" : { "refund_history" : 1 }, "host" : "emp1-PC:27017", "accesses" : { "ops" : 0, "since" : ISODate("2023-05-02T14:25:18.998+05:30") }, "spec" : { "v" : 2, "key" : { "refund_history" : 1 }, "name" : "refund_history_1" } } ], "index details" : { "metadata" : { "formatVersion" : 8 }, "creationString" : "access_pattern_hint=none,allocation_size=4KB,app_metadata=(formatVersion=8),assert=(commit_timestamp=none,durable_timestamp=none,read_timestamp=none,write_timestamp=off),block_allocation=best,block_compressor=,cache_resident=false,checksum=on,colgroups=,collator=,columns=,dictionary=0,encryption=(keyid=,name=),exclusive=false,extractor=,format=btree,huffman_key=,huffman_value=,ignore_in_memory_cache_size=false,immutable=false,import=(compare_timestamp=oldest_timestamp,enabled=false,file_metadata=,metadata_file=,repair=false),internal_item_max=0,internal_key_max=0,internal_key_truncate=true,internal_page_max=16k,key_format=u,key_gap=10,leaf_item_max=0,leaf_key_max=0,leaf_page_max=16k,leaf_value_max=0,log=(enabled=true),lsm=(auto_throttle=true,bloom=true,bloom_bit_count=16,bloom_config=,bloom_hash_count=8,bloom_oldest=false,chunk_count_limit=0,chunk_max=5GB,chunk_size=10MB,merge_custom=(prefix=,start_generation=0,suffix=),merge_max=15,merge_min=0),memory_page_image_max=0,memory_page_max=5MB,os_cache_dirty_max=0,os_cache_max=0,prefix_compression=true,prefix_compression_min=4,readonly=false,source=,split_deepen_min_child=0,split_deepen_per_child=0,split_pct=90,tiered_object=false,tiered_storage=(auth_token=,bucket=,bucket_prefix=,cache_directory=,local_retention=300,name=,object_target_size=0),type=file,value_format=u,verbose=[],write_timestamp_usage=none", "type" : "file", "uri" : "statistics:table:index-22--4789062642330656730", "LSM" : { "bloom filter false positives" : 0, "bloom filter hits" : 0, "bloom filter misses" : 0, "bloom filter pages evicted from cache" : 0, "bloom filter pages read into cache" : 0, "bloom filters in the LSM tree" : 0, "chunks in the LSM tree" : 0, "highest merge generation in the LSM tree" : 0, "queries that could have benefited from a Bloom filter that did not exist" : 0, "sleep for LSM checkpoint throttle" : 0, "sleep for LSM merge throttle" : 0, "total size of bloom filters" : 0 }, "block-manager" : { "allocations requiring file extension" : 0, "blocks allocated" : 0, "blocks freed" : 0, "checkpoint size" : 57356288, "file allocation unit size" : 4096, "file bytes available for reuse" : 0, "file magic number" : 120897, "file major version number" : 1, "file size in bytes" : 57372672, "minor version number" : 0 }, "btree" : { "btree checkpoint generation" : 6113, "btree clean tree checkpoint expiration time" : NumberLong("9223372036854775807"), "btree compact pages reviewed" : 0, "btree compact pages rewritten" : 0, "btree compact pages skipped" : 0, "btree skipped by compaction as process would not reduce size" : 0, "column-store fixed-size leaf pages" : 0, "column-store fixed-size time windows" : 0, "column-store internal pages" : 0, "column-store variable-size RLE encoded values" : 0, "column-store variable-size deleted values" : 0, "column-store variable-size leaf pages" : 0, "fixed-record size" : 0, "maximum internal page size" : 16384, "maximum leaf page key size" : 1474, "maximum leaf page size" : 16384, "maximum leaf page value size" : 7372, "maximum tree depth" : 0, "number of key/value pairs" : 0, "overflow pages" : 0, "row-store empty values" : 0, "row-store internal pages" : 0, "row-store leaf pages" : 0 }, "cache" : { "bytes currently in the cache" : 563, "bytes dirty in the cache cumulative" : 0, "bytes read into cache" : 64540, "bytes written from cache" : 0, "checkpoint blocked page eviction" : 0, "checkpoint of history store file blocked non-history store page eviction" : 0, "data source pages selected for eviction unable to be evicted" : 0, "eviction gave up due to detecting an out of order on disk value behind the last update on the chain" : 0, "eviction gave up due to detecting an out of order tombstone ahead of the selected on disk update" : 0, "eviction gave up due to detecting an out of order tombstone ahead of the selected on disk update after validating the update chain" : 0, "eviction gave up due to detecting out of order timestamps on the update chain after the selected on disk update" : 0, "eviction gave up due to needing to remove a record from the history store but checkpoint is running" : 0, "eviction walk passes of a file" : 0, "eviction walk target pages histogram - 0-9" : 0, "eviction walk target pages histogram - 10-31" : 0, "eviction walk target pages histogram - 128 and higher" : 0, "eviction walk target pages histogram - 32-63" : 0, "eviction walk target pages histogram - 64-128" : 0, "eviction walk target pages reduced due to history store cache pressure" : 0, "eviction walks abandoned" : 0, "eviction walks gave up because they restarted their walk twice" : 0, "eviction walks gave up because they saw too many pages and found no candidates" : 0, "eviction walks gave up because they saw too many pages and found too few candidates" : 0, "eviction walks reached end of tree" : 0, "eviction walks restarted" : 0, "eviction walks started from root of tree" : 0, "eviction walks started from saved location in tree" : 0, "hazard pointer blocked page eviction" : 0, "history store table insert calls" : 0, "history store table insert calls that returned restart" : 0, "history store table out-of-order resolved updates that lose their durable timestamp" : 0, "history store table out-of-order updates that were fixed up by reinserting with the fixed timestamp" : 0, "history store table reads" : 0, "history store table reads missed" : 0, "history store table reads requiring squashed modifies" : 0, "history store table truncation by rollback to stable to remove an unstable update" : 0, "history store table truncation by rollback to stable to remove an update" : 0, "history store table truncation to remove an update" : 0, "history store table truncation to remove range of updates due to key being removed from the data page during reconciliation" : 0, "history store table truncation to remove range of updates due to out-of-order timestamp update on data page" : 0, "history store table writes requiring squashed modifies" : 0, "in-memory page passed criteria to be split" : 0, "in-memory page splits" : 0, "internal pages evicted" : 0, "internal pages split during eviction" : 0, "leaf pages split during eviction" : 0, "modified pages evicted" : 0, "overflow pages read into cache" : 0, "page split during eviction deepened the tree" : 0, "page written requiring history store records" : 0, "pages read into cache" : 6, "pages read into cache after truncate" : 0, "pages read into cache after truncate in prepare state" : 0, "pages requested from the cache" : 0, "pages seen by eviction walk" : 0, "pages written from cache" : 0, "pages written requiring in-memory restoration" : 0, "the number of times full update inserted to history store" : 0, "the number of times reverse modify inserted to history store" : 0, "tracked dirty bytes in the cache" : 0, "unmodified pages evicted" : 0 }, "cache_walk" : { "Average difference between current eviction generation when the page was last considered" : 0, "Average on-disk page image size seen" : 0, "Average time in cache for pages that have been visited by the eviction server" : 0, "Average time in cache for pages that have not been visited by the eviction server" : 0, "Clean pages currently in cache" : 0, "Current eviction generation" : 0, "Dirty pages currently in cache" : 0, "Entries in the root page" : 0, "Internal pages currently in cache" : 0, "Leaf pages currently in cache" : 0, "Maximum difference between current eviction generation when the page was last considered" : 0, "Maximum page size seen" : 0, "Minimum on-disk page image size seen" : 0, "Number of pages never visited by eviction server" : 0, "On-disk page image sizes smaller than a single allocation unit" : 0, "Pages created in memory and never written" : 0, "Pages currently queued for eviction" : 0, "Pages that could not be queued for eviction" : 0, "Refs skipped during cache traversal" : 0, "Size of the root page" : 0, "Total number of pages currently in cache" : 0 }, "checkpoint-cleanup" : { "pages added for eviction" : 0, "pages removed" : 0, "pages skipped during tree walk" : 0, "pages visited" : 0 }, "compression" : { "compressed page maximum internal page size prior to compression" : 16384, "compressed page maximum leaf page size prior to compression " : 16384, "compressed pages read" : 0, "compressed pages written" : 0, "number of blocks with compress ratio greater than 64" : 0, "number of blocks with compress ratio smaller than 16" : 0, "number of blocks with compress ratio smaller than 2" : 0, "number of blocks with compress ratio smaller than 32" : 0, "number of blocks with compress ratio smaller than 4" : 0, "number of blocks with compress ratio smaller than 64" : 0, "number of blocks with compress ratio smaller than 8" : 0, "page written failed to compress" : 0, "page written was too small to compress" : 0 }, "cursor" : { "Total number of entries skipped by cursor next calls" : 0, "Total number of entries skipped by cursor prev calls" : 0, "Total number of entries skipped to position the history store cursor" : 0, "Total number of times a search near has exited due to prefix config" : 0, "bulk loaded cursor insert calls" : 0, "cache cursors reuse count" : 0, "close calls that result in cache" : 0, "create calls" : 0, "cursor next calls that skip due to a globally visible history store tombstone" : 0, "cursor next calls that skip greater than or equal to 100 entries" : 0, "cursor next calls that skip less than 100 entries" : 0, "cursor prev calls that skip due to a globally visible history store tombstone" : 0, "cursor prev calls that skip greater than or equal to 100 entries" : 0, "cursor prev calls that skip less than 100 entries" : 0, "insert calls" : 0, "insert key and value bytes" : 0, "modify" : 0, "modify key and value bytes affected" : 0, "modify value bytes modified" : 0, "next calls" : 0, "open cursor count" : 0, "operation restarted" : 0, "prev calls" : 0, "remove calls" : 0, "remove key bytes removed" : 0, "reserve calls" : 0, "reset calls" : 0, "search calls" : 0, "search history store calls" : 0, "search near calls" : 0, "truncate calls" : 0, "update calls" : 0, "update key and value bytes" : 0, "update value size change" : 0 }, "reconciliation" : { "approximate byte size of timestamps in pages written" : 0, "approximate byte size of transaction IDs in pages written" : 0, "dictionary matches" : 0, "fast-path pages deleted" : 0, "internal page key bytes discarded using suffix compression" : 0, "internal page multi-block writes" : 0, "leaf page key bytes discarded using prefix compression" : 0, "leaf page multi-block writes" : 0, "leaf-page overflow keys" : 0, "maximum blocks required for a page" : 0, "overflow values written" : 0, "page checksum matches" : 0, "page reconciliation calls" : 0, "page reconciliation calls for eviction" : 0, "pages deleted" : 0, "pages written including an aggregated newest start durable timestamp " : 0, "pages written including an aggregated newest stop durable timestamp " : 0, "pages written including an aggregated newest stop timestamp " : 0, "pages written including an aggregated newest stop transaction ID" : 0, "pages written including an aggregated newest transaction ID " : 0, "pages written including an aggregated oldest start timestamp " : 0, "pages written including an aggregated prepare" : 0, "pages written including at least one prepare" : 0, "pages written including at least one start durable timestamp" : 0, "pages written including at least one start timestamp" : 0, "pages written including at least one start transaction ID" : 0, "pages written including at least one stop durable timestamp" : 0, "pages written including at least one stop timestamp" : 0, "pages written including at least one stop transaction ID" : 0, "records written including a prepare" : 0, "records written including a start durable timestamp" : 0, "records written including a start timestamp" : 0, "records written including a start transaction ID" : 0, "records written including a stop durable timestamp" : 0, "records written including a stop timestamp" : 0, "records written including a stop transaction ID" : 0 }, "session" : { "object compaction" : 0, "tiered operations dequeued and processed" : 0, "tiered operations scheduled" : 0, "tiered storage local retention time (secs)" : 0 }, "transaction" : { "race to read prepared update retry" : 0, "rollback to stable history store records with stop timestamps older than newer records" : 0, "rollback to stable inconsistent checkpoint" : 0, "rollback to stable keys removed" : 0, "rollback to stable keys restored" : 0, "rollback to stable restored tombstones from history store" : 0, "rollback to stable restored updates from history store" : 0, "rollback to stable skipping delete rle" : 0, "rollback to stable skipping stable rle" : 0, "rollback to stable sweeping history store keys" : 0, "rollback to stable updates removed from history store" : 0, "transaction checkpoints due to obsolete pages" : 0, "update conflicts" : 0 } } }
