Currently we are using mongo to run the JavaScript files to get data.
Now we want to use mongosh to run .js files as mongo is deprecating in future releases.
we are experiencing the inclusion of irrelevant data at the top of our output files even after using ‘–quiet’ option. Specifically, we observe lines similar to:
'Prod [direct: other] eye_db>
Prod [direct: other] eye_db> … … … … … ’
And also if the output data is having 10000 records , it is showing 100 records and at the bottom
‘… 9900 records more`’ in output file
How to solve this?
@Pavan_Vinnakota can you share the script you are running and how you are running it?
Hi @Massimiliano_Marcon ,
Thank you for the replay.
The script i am using is below
db.getMongo().setReadPref("secondary")
db.tracker.aggregate([
{$match: {
lastModifiedOn:{$gte:'2024/02/19'}, status: "inProgress"
{$group: {_id: "$trackerId",count:{$sum:1}}},
{$project:{count:"$count"}}]).forEach(function(doc){
print(doc._id+","+doc.count)
mongosh marketplace --authenticationDatabase marketplace -u <> -p <> --host host.in --port 27017 --quiet < file.js > data.csv
The output file is having this at top along with required data:
Prod [direct: other] marketplace>
Prod [direct: other] marketplace> … … … … … … …
How to avoid this in output file.
Please suggest.
can you try with:
mongosh marketplace --authenticationDatabase marketplace -u <> -p <> --host host.in --port 27017 --quiet -f file.js > data.csv
Working as expected.
Thank you for the support.
system
(system)
Closed
February 27, 2024, 7:41am
6
