Have you updated mongodb into your PATH?
Show us the output of echo $PATH
Can you run mongo --nodb command by giving full path of mongo.exe?
Any update on this ?
If $PATH doesn’t work then try echo %PATH% and share the output with us.
~ Shubham
Thankyou soo much for. Your concern …its solved…now if I Type mongo --db i can see my version of my mongo db 4.2.7…
If i ever need any further assistance i will contact you people❤️
Hi i am having similiar problems.
i have updated my path and it gives the following error
“zsh: command not found: mongo”
Can you run the command using full path of mongo.exe and see
same here with bash, I have installed 4.2.7
-bash: mongo: command not found
Hi, I found solution for this
just use => export PATH="$PATH:x"
x => path to bin like (/Users/avinash/mdb/mongodb-x86_64-enterprise-4.2.7/bin)
Hi @Faith_Rambire,
Did you switch to the bash shell before setting up the path ?
Also, this ![]()
~ Shubham
hi i ended up installing using brew
I’m glad your issue got resolved. Please feel free to get back to us if you have any other query.
~ Shubham
