Hybrid AI from edge to cloud with ObjectBox + MongoDB
Affiliation note: I’m with ObjectBox.
Another tutorial around MongoDB + ObjectBox just went live - and this time it is about Edge AI + Cloud AI, running local vector search (HNSW) on the device/edge with ObjectBox being superfast, private, and offline-available (independant from an Internet connection) and going to MongoDB for when you need more powerful AI models and have the connectivity.
–> https://dev.to/mongodb/hybrid-ai-from-the-edge-to-the-cloud-with-mongodb-objectbox-38i0
I’m curious: how important is the combination of local AI + cloud AI for your applications right now? And in that scenario, do you also need Data Sync?
Happy to answer ObjectBox-side questions :slight_smile:
Thank for sharing, impressive priorities
