How to rename the fields using FindIterable.map() function programmatically using Java?
MongoDoc:
"first_name" : "Terry",
"last_name" : "James"
Expected Format:
"fname" : "Terry",
"lname" : "James"
Sample Code:
import com.mongodb.ConnectionString;
import com.mongodb.MongoClientSettings;
import com.mongodb.client.*;
import com.mongodb.client.model.Filters;
import com.mongodb.client.model.Projections;
import org.bson.Document;
import org.bson.codecs.configuration.CodecRegistry;
import org.bson.codecs.pojo.PojoCodecProvider;
import org.bson.conversions.Bson;
import java.util.Set;
import java.util.concurrent.ConcurrentHashMap;
import static com.mongodb.client.MongoClients.create;
import static org.bson.codecs.configuration.CodecRegistries.fromProviders;
import static org.bson.codecs.configuration.CodecRegistries.fromRegistries;
public class MyFind {
public static void main(String[] args) {
String connectionString = "< Enter the connection string >";
String database = "< Enter the database >";
String collectionName = "< Enter the collectionName >";
new MyFind().executeMongoFind(connectionString, database, collectionName);
private void executeMongoFind(String connectionString, String database, String collectionName) {
MongoClientSettings settings = getMongoClientSettings(connectionString);
MongoClient client = create(settings);
MongoDatabase mongoDatabase = null;
try {
mongoDatabase = client.getDatabase(database);
Bson filterCriteria = getFilter();
Bson projectionFields = getProjectionFields();
FindIterable iterable = mongoDatabase.getCollection(collectionName).find(filterCriteria);
iterable = iterable.projection(projectionFields);
db.collection_name.find({},{'first_name': 1, _id:0})
.map( doc => ({ firstName: doc['first_name']}));
/* iterable.map(Function fn) */
MongoCursor<Document> mongoCursor = iterable != null ? iterable.iterator() : null;
while (mongoCursor.hasNext()) {
Document doc = mongoCursor.next();
System.out.println(doc.toJson());
} catch (Exception e) {
e.printStackTrace();
private MongoClientSettings getMongoClientSettings(String connectionString) {
ConnectionString connection = new ConnectionString(connectionString);
CodecRegistry codecRegistry = fromRegistries(MongoClientSettings.getDefaultCodecRegistry(),
fromProviders(PojoCodecProvider.builder().automatic(true).build()));
MongoClientSettings settings = MongoClientSettings.builder()
.applyConnectionString(connection)
.codecRegistry(codecRegistry)
.build();
return settings;
private Bson getProjectionFields() {
Set<String> projectionFieldSet = new ConcurrentHashMap<>().newKeySet();
projectionFieldSet.add("first_name");
projectionFieldSet.add("last_name");
Bson projectionFields = Projections
.fields(Projections.include(projectionFieldSet
.stream().toArray(String[]::new)), Projections.excludeId());
return projectionFields;
private Bson getFilter() {
Bson filterCriteria = Filters.and(Filters.eq("first_name", "Terry"));
return filterCriteria;
